Just replaced the clutch, flywheel, and slave cylinder on my 2002 Wrangler. After bleeding slave cylinder I had great pressure on new clutch and it went into 1st perfectly. But after my first shift I lost all pressure and could not get my clutch to engage at all. Also had a leak directly above the transmission mount. Slave cylinder was not the cause of the fluid leak. Could not investigate more at the time. Any ideas of what I should double check? Should I bleed the new slave cylinder more?
