Hi,
I have a TJ from 97 with a working AC on which the climate control (warm or cold) is a slider. Since I bought the car the cable driven by the slider is broken (it is too loose and then tension mechanics is broken) so the slider does not activate the lever under the glove box properly.
As a quick fix, I was regulating by grabbing under the glovebox and turning the lever.
One morning, I try to switch from cooling to heating and the lever snapped. I am blocked in heating which was fine for Xmas but the weather is improving quickly and I want to be able to want to use the AC again.
My repair manual is for a jeep wrangler from 99 and therefore does not include the cable system. I would appreciate if someone could give me a diagram.
I am wondering whether I need to drop the dashboard (like I did to fix my AC) to have access to the HVAC box or if I can just replace the lever. I did not try to extract it with pliers yet.
Also if anyone as a part number for the cable and the lever it would be great.
I uploaded some pictures of the broken parts here:
https://plus.google.com/u/0/photos/111948549216054133115/albums/5695374547157810833
Thanks,
Pierre
Thanks,
Pierre
