1 - 7 of 7 Posts
I’m tracing down a no-power to my blower motor. I checked all the fuses and some have power, others don’t.
This is what I found when I separated the fuse block. Aside from cleaning this side, how do I take the wires out of the backside to examine? Right now they’re covered with some sort of gunk.
1985 Jeep CJ7
I believe it’s some kind of factory die-electric grease or sealant. Mine looked the same. I simply carefully cleaned each terminal and reapplied die-electric grease on each one. I didn’t tamper with the factory sealing. You can remove however by squeezing terminal (longated) and pushing it through.
Spray electrical cleaner inside and use an old toothbrush or those wooden throw away brushes from Home Depot. Then apply the die-electrical grease.
1 - 7 of 7 Posts
