Hi all,
I'm looking to start collecting parts to put together an axle swap and was hoping for some advice on the best path forward. The goal is to eventually run 35s. I know this stuff has been covered but every jeep/jeeper's situation is a little different and I have a few specific questions.
I currently have the stock narrow track D30 and AMC20 (upgraded to 1 piece shafts). I'm running 31x10.5s on stock wheels and 1.25 (2.5 of total width added per axle) spydertrax wheel spacers at each corner to keep the tires off the leaf springs at full lock. I don't mind continuing to run wheel spacers in the future if need be. Based on how the 31s sit there's no way I would be able to fit 35s without giving up turning radius and constantly having the tire into the springs/frame when flexed.
Between the width issues and 35s pushing the limits of the D30 I'm mostly looking at D44 swaps from FSJs. I already have a D44 from an 86' CJ7 lying around for the rear (54.5 wms). For simplicity and cost reasons I would like to use it if I can but could always sell it and source something else if needed. I can get a wagoneer front axle, cut it down to CJish width (I believe it comes out to roughly 57.25") which would probably best match the width of CJ7 D44 I already have but I am concerned that it won't give me enough tire to spring clearance for 35s. I could also outboard the springs and run the wagoneer axle as is (about 60") although that doesn't help with tire to spring clearance at all just may be a little easier to do and gives a little extra track width. The other option I've been looking at is cut down a Wide Track FSJ D44 from a J truck to bolt to the CJ (I believe it comes out to about 61") which would give more clearance for 35s as there is a greater distance between wms and spring but would leave my front axle 6 1/2 inches wider then the rear (4 inches wider w/ spacers in the rear). Are there any issues with width differences that large? I'd rather not outboard the springs and run a Wide Track FSJ axle at full width as I'd rather not go quite that wide and would then definitely need to source a new rear axle.
Basically boils down to 3 questions:
1: Will 35s clear the front leaf springs at full lock if I run a wagoneer axle or do I have to run a WT FSJ axle?
2: What is the max width difference I can get away with between my front and rear axle? Obviously having a front axle slightly wider is normal and even desirable but how much wider can it be without causing any problems?
2: Should I keep the CJ7 D44 I already have or am I better off sourcing a different rear axle?
Thanks so much for all the help and advice, it is greatly appreciated.
