Tired of piss yellow weak CJ lights installed the high dollar led units. Bright AF. Will a relay upgrade make any more difference? Asking for a friend.
Yeah, they come with enough wire harness to bulb socket length to locate the relays outside the grill if you want. I'm surprised you don't have room inside the grill behind the passenger side bulb. I did and I have an a/c condenser/hoses and fan wiring in there taking up space too.Does the Hella harness everyone here is buying have enough wire between the relays and bulb sockets that the relays can be back from the grille? I ordered a different one, and the wiring is only long enough to go back a few inches from the grille with the relays. I have no room up there.
The only issue I have with those fancy Hella relays though is replacement - they are not a standard design, so you'd want to have a spare with you in case of failure.
I didn't like the 4 relays at first but it leads to less points of failure that way.I'm thinking maybe just tap into the plow/grille headlight switch now that I see those. A relay on the lamp side of that switch would be after the headlight and high beam switch, so it would be almost the same effect. A bank of 4 - plow hi and low, grille high and low - all connected under the dash....
John, if you use one for the blower, you'd either lose low and medium, or have to wire the blower pigtail to pin 30 and then high speed power from the battery on pin 87, with low medium on 87a, using the high speed wire from the switch to turn on the relay. That is a good idea, too - that switch gets kinda over-warm on high speed for any length of time...
