I just received mine and they look the same. I'm really looking forward to getting this in and seeing at night!
I just received mine and they look the same. I'm really looking forward to getting this in and seeing at night!Ok boys, these came today from Amazon for $35. They look pretty legit to me.
That is exactly what I was saying earlier, but you did include another piece of beneficial information. :thumbsup:
Yep, I run a short jump lead from the main feed (30) to the relay coil (86).
Then run the ground (85) to the switch, then to ground. If you are running multiple lights or a switch pod, you can install a ground buss.
The only real downfall is you don't have the option of a circuit routed through the ignition switch, which means it is possible to bump a switch with the ignition off and have a light left on long enough to melt a cover or run down the battery.
Bingo.You could run those lighting grounds through a key operated relay that is inside the cab
I like having the headlight harness use standard 5 pin Bosch style relays
I reordered and received the Hella's this time. Good luck with your order.Just ordered this again, see what I get Wednesday.
Thanks for the heads up. I'll review the thread more carefully.The Hellas have 2 power leads, one for each fuse. I've read bad reviews with just the one lead.
Woodman, that's what I received the first time I ordered them (post 45 or 46).
Hoov, I'm a firm believer of your hypothesis!!
This is so easily accomplished just by removing the main feed from the light switch and routing a power lead from the accessory circuit.Yep, I run a short jump lead from the main feed (30) to the relay coil (86).
I'd be interested in seeing what you're thinking. I have my own idea, but it sounds very similar to yours.This is so easily accomplished just by removing the main feed from the light switch and routing a power lead from the accessory circuit.
Since all they switch is a relay, current load is not a problem to use the accessory circuit.
If anyone is interested, I could draw up instructions to do this. I think I may do this myself.
I was working on this yesterday but I'm going to have to figure out the load all the parking lights put on the circuit and select the proper fuse size.I'd be interested in seeing what you're thinking. I have my own idea, but it sounds very similar to yours.
Ok, you're definitely not thinking what I'm thinking. Now I really want to see what you're up to.:surprise:I was working on this yesterday but I'm going to have to figure out the load all the parking lights put on the circuit and select the proper fuse size.
It would be best to connect it to the back of the voltmeter to draw power so as not to load down the rest of the circuits.
Simplest is to do it this way.Ok, you're definitely not thinking what I'm thinking. Now I really want to see what you're up to.:surprise:
:thumbsup:Simplest is to do it this way.
I was not sure if the fuse could handle both the fan motor and the parking lights. Might need to pick a different plug like the "Cruse" Plug but that has the cigar lighter on the circuit. Maybe even the "Radio" of "Clock" position and change the fuse size.
OR just hook it up to the back of the voltmeter with a inline fuse.
Either way, you lights will be OFF in the LOCK, OFF or START position but can be ON in the ACC of RUN position.
