hmmmm ....not sure why I have 3 different size pix here but if any one wants I will redo pix
well it should .... hard top only weighs about 200lbs or so and a garage door is alot more than thatjeep795 said:hmmm, seeing as i work at overhead door....imagine if that were picked up by a garage door opener? it just might lift it
Yeah, but garage doors have the helper springs. Most garage doors are set to have a 20-25# lifting weight.raysnutt18 said:well it should .... hard top only weighs about 200lbs or so and a garage door is alot more than that
i really like the idea of the light ring...i have been working on some ideas but that one sounds the best so far.erickpl said:I like that setup. To clean it up and protect the hole, perhaps a light ring, like what you'd put around a recessed can light, would look a bit nicer and protect the drywall ceiling a bit.
Did you use any kind of insulating material between the joists and the motor mounts?
Pics of how you mounted the stuff in the attic would be great.
