I need to figure out what to do for an in-tank pump for a 4.0 conversion. I'm not interested in an externally mounted pump.
Choices are:
1) The Novak pump. Plug and play but expensive.
2) 2.5 YJ sender w/correct sized pump. Even if I reverse the ohms the fuel gauge will still read a little off
3) Modify the CJ sender. Still haven't found a good solution to have a water (gas) tight connection for the wiring.
4) Use a separate fuel hanger. Will need to drill the tank and cap one of the lines on the Jeep sender.
I'm leaning towards option 4. I have an extra fuel hanger/pump from a early 90s Range Rover that fits nicely in the tank. I don't know the rating of the pump but it will run any of the older RV8s (3.9, 4.2, 4.6) so I'm fairly certain it will work on the Jeep 4.0.
I mocked up the set up with an old tank and pump and here is how it would look. I'd just need to add rivnuts to secure the pump hanger and use the Rover cork gasket to seal it up.
Any opinions on set up #4?
Choices are:
