1 - 7 of 7 Posts
Long time reader, first time poster here,
(1992 Cherokee Laredo np231)
So, in my haste to get my output shaft seal replaced last night, I decided to use a screwdriver instead of a seal puller to remove the old leaky seal… dumb move.
I managed to get the seal out but chipped a small piece of the output shaft housing in the process. (Linked photo) I put the chipped piece back in place but you can see where it’s broke
Does anyone one know how detrimental that is the the seal’s ability to well, seal? Should I opt for a new one from crown or eBay or leave it? Any opinions or tips would be greatly appreciated, thank you.
Tin Nickel Automotive tire Gas Silver
Looks OK to me. Since that is the outside part that the seal sits in, no place for oil to leak out. Any farther down would be a problem but this can be fixed. You could take the whole thing off and have it heli-arc welded. But I would use a very good epoxy like Marine Tex to glue it back in place with a decent amount on the outside for support. Then when you put the seal in, use some good sealer especially at that spot.
I weld, but aluminum requires TIG which I don't have either. My buddy does TIG and I had him repair a cracked outboard motor lower unit. It is an art you can really appreciate.
· Mopar Nut
2004 Grand Cherokee Laredo, 4.7-N
In all honesty, that chip wouldn't bother me at all. I might even mount it on my "wall of shame". I'd pop a new seal in, goober some RTV over the now missing hunk. I guess I might go as far as to put a thin layer of RTV on the inside before I pressed the seal in as well. But that's all just me. MHO, my $0.02...
PS - Humans learn from their mistakes, NOT their success! This could have been much worse. Find solace in knowing you won't do this again!
1 - 7 of 7 Posts
