1 - 10 of 10 Posts
Wasn't there an aluminum housing you could buy? Seems like you could buy it from advance auto... Read that many years ago and meant to buy some but never got a round-tu-it.
I did the suggested method of removing alternator. I left the tab that said "FRONT" on it. I forgot to put some sealant on the bolts then and it leaked. FSM says you can just remove it without taking anything off so I tried, but I the tab prevented that. I cut the tab off of mine that said "FRONT". I ended up doing the hughes plenum a few months later and I was able to pull the housing out that time without unbolting anything (I only did it to try for future knowledge in case I had to take it off again). After doing the plenum and sealing bolts and what not, it's been untouched since then (June 2017).
1 - 10 of 10 Posts
