Hello all,
I am trying to ID a rattling sound on my 03 WJ with 199K miles. It is in excellent condition. Originally, there were two sounds (front and rear) but after my troubleshooting the front sound has been take care of (see below). The main sound seems to be coming from the center/rear of the vehicle and it can only be heard when the vehicle is in motion. Specifically, when hitting any kind of bump or hole in the road at 10 - 30 mph.
The strange part is that it is definitely getting worse, but my Jeep is handling fine. I only hear the sound, which can best described has a deep metallic sound that is loud and then repeats several times while dampening out (almost like it is ringing). Kind of like if you hit two pans together pretty hard and then did that again (rapidly) 5 times getting softer each time. Sound is not present when idling or driving on smooth roads.
Here is everything I have ruled out / fixed so far:
- Front/Rear Shocks - these are pretty new (installed back in 2019) and all of the bolt connections appear to be tight
- Heat Shield Above the Exhaust - the shield had fallen onto the exhaust system and would rattle a bit, so after much effort and a trip to the specialty drawer at the hardware store, I was able to reattach the heat shield to the body of the Jeep. Fixed but no real improvement on the rattling noises.
- Front Sway Bar / Sway Bar Links - according to various forums, this is usually the cause of such sounds. Despite the high mileage, none of my front sway bar bushings and sway bar links have any play in them (literally zero play). From what I can tell, they are perfectly fine.
- Front Drag Link Ends / Sleeve - I really thought this was the culprit... when I was investigating my front sway bar, I realized my drag link had a ton of play in it and that the bushings on both link ends were completely shot. I replaced this (new everything) and had my vehicle aligned. A bit of the rattling from the front stopped but the main sound was still present. Steering is much more responsive though!
- Driver Side Lower Control Arm - when I had my vehicle aligned, I asked the shop to poke around and try to ID the sound. They said that the bushings on my driver side lower control arm were shot and that could cause this type of noise. I replaced it myself with the help of a friend. The sounds from the front of my vehicle have completely stopped! But the main sound persists...
- Rear Sway bar / Sway Bar Links - I investigated these and they seem to be fine. There is a tiny, tiny bit of play in them but it is barely noticeable. I do not think this is the issue.
- Rear Control Arms (Upper and/or Lower) - I cannot really tell if these are bad or not... while my vehicle is on the ground, there seems to be no play in any of the control arms in the back. I am going to try lifting it up next week to see. I am guessing this because the sound is so loud and because it only happens when I hit bumps / holes in the road.
- Rear Axle - idk just seems possible
