Well finally got Jeep running <50 miles Sketching sound motor goes dead with wife in it headed for breakfast
Take a cab home get Dodge and tow bar and go retrieve the CJ
Rotor turn but way out of time. Just put in NEW Time chain, Dizzy gears, fixed pick up, have 65lbs at speed 25 at idle so what the hell.
Surely not another find from the PO who should not even own a screw driver.
Yep he got me
Took off front cover and there it is. Brand dist drive on cam chewed up. Not a drop of oil to be found in there
something doesn't look right with that cam bearing.
Tear motor down completely. Punch out bearing and low and behold the dickhead installed it wrong. No it didn't spin either no gauling at all on either side of bearing or the cam. Cam is still goog to go
Well that ends all his f(&%^&%)*&% ups. Motor getting rebuild by me now it will be my fault
Pics of the front of block is how we found it. Was not wiped down ZIP for oil
Anyone have a pic of cam bearings installed. Curious as the remaining ones the hole is at the bottom is this correct. I'm having the block machined, tanked and them install the cam bearings
Just need to make sure this crap don't happen again.
I Love shade trees. I hate shade tree mechanics
Yep he got me
