41 - 60 of 65 Posts
Price $450
Pros doesn't scratch
looks sick
Cons gotta make sure you wash ur wheel barrels also when washing your car because everythig underneath shows... but it looks awsome
Recommended yes
Comments: these fenders where a good choice.
they are slim and the material doesn't scratch.
it looks like you have a lift kit, and gives better clearence when offroading and need to turn your wheels on weird angles.
Awsome product, glad i went with bushwacker.
Price $450
Pros Looks good, straight forward install.
Cons None yet.
Recommended yes
Comments: I just put mine on over the last three days (few hours a day). It was almost 8 hours by the time I was all cleaned up.
Like others said; the black/white is backwards, and you can't hurt anything by hooking it up wrong.
Better to trim the fender liners a little long than a little short; I have one small spot where there's a gap.
The rubber gasket is finnicky. It doesn't stick in all spots; better on the rear than the front. The instructions say to stop at the 'tube feature' but go another inch on each side of all 4 fenders. I had about a foot of gasket left over.
Honestly, with all the curves and details of the JK body, I'm surprised they fit so well.
Price $580
Rating 2
Pros looks great but will not last on a true wheeling jeep
Cons You have to cut inner fenders on the jk's ( they do not provide you a template ) there is no upper support ( no hardware ie : screws or bolts ) except dbl sided tape to hold the top part of the fender to the body
Recommended no
Comments: I should have read the directions before i painted the product ( because i would have returned them ) I do not like the way they use dbl sided tape to hold the top of the flare to the body ( the ONLY thing holding the upper flare to the body ) Every time someone goes to lean on my flares i cringe , i am afraid the flares will pull away from the fender. I can not see them lasting four wheeling the first time my tire hits the flare i imagine it will break right off. but then that will be an excuse to buy the steel flat flares i should have bought :thumbdown::thumbdown:
Price $500
Pros Like the look, Cover the wheels now, keep the mud out of the interior.
Cons Expensive plastic, no body protection, labor intensive to install.
Recommended yes
Comments: I like the look of the flares, they keep mud out of the interior now. No real body protection and they are labor intensive to install. A little pricy for plastic in my opinion.
Price $450
Pros Easy to install. Looks great
Cons None really.
Recommended yes
Comments: Install was fairly quick and relatively painless. Getting the speed clips to line up with the screws was the hardest part. Other than that they look great. I'm still having an issue getting the side markers to light up but I think I may have polarity reversed on the LED wires.
Price $430
Pros Max Wheel coverage, Great look!
Cons Installation was a little longer then described.
Recommended yes
Comments: These fenders added a great look for my TJ that I havent seen anywhere in my area yet. The installation was a little more difficult then the Bushwacker install video, rear wheel well liner needed to be removed. Everything was pretty simple and im sure the while install would have went pretty smooth but all my mount screws were seized and i had to custom install mount brackets.
Price $600
Pros Excellent Flat Fenders
Cons LED Light wires could be a little longer and the connectors included are cheap.
Recommended yes
Comments: Excellent package but I would recommend different wiring connectors for the front LED markers.
Price $500
Pros fitment
Cons not a big fan of double sided tape on a fender,aspecially on a daily driver..
Recommended yes
Comments: installed these on my jeep..fit good but a little tricky getting them over the mounting brackets by myself.also not a big fan of double sided tape on a daily driver. time will tell I guess...other than that fits good and looks great..i did not paint.
Price $450
Pros great looks, durable
Cons expensive, difficult to install
Recommended yes
Comments: bit on the expensive side but they look great and won't warp like my Xenon flares did.
Price $552
Pros Additional clearance. Great look. Lose the single-bulb reflector-lens side lamps, gain 6 LEDs per front flare.
Cons As far as I'm concerned, none.
Recommended yes
Comments: These flares look phenomenal. If you're considering swapping out your factory flares, you won't go wrong on these. Bottom line: install yourself; take your time; enjoy the beauty.
Installed on a 2010 JKU. If you need any help, feel free to PM me.
Price $385
Pros -More tire clearance over stock fender flares
-Look great
Cons -Not the easiest to install
-Will not withstand trail rash any better than a stock plastic fender flare
Recommended no
Comments: When I purchased these flares I was a Jeep novice (I still am really) and I was planning on mainly riding on the beach and basic trail riding. However, two weeks after I installed them, I bumped a pole on my carport with my front driver side flare and it is now forever deformed. You can not fix plastic once it's damaged. I didn't even get a good trail story out of it. So, with that being said, I plan to replace them with metal tube fender flares in the future. While these fender flares look nice, they are just plastic like the factory and therefore they do not withstand the abuse a Jeep gets put through on the trails (or carports). Therefore, I recommend that if you are considering a flat fender flare to get a metal tube fender flare instead of the Bushwacker Flat Fender Flares.
Price $450
Pros Look great.. Less chance of rubbing with wider tires, cheaper than tube steel .... Easy install
Cons Not tube steel
Recommended yes
Comments: Great for a little extra room and just look great
Price $470
Pros Nice coverage, extended clearance, fits really well
Cons price....
Recommended yes
Comments: My body was "clearanced" by the previous owner in the rear so I had to bend the body back strait. Once this was done it was a very simple bolt on affair and one hole to drill on each side. When I put 35's on it I will trim the body and flare to match up to the flat portion which should give plenty of clearance.
Price $544
Rating 4
Pros -Looks Great.
-Make lift looks bigger
Cons -LED Amber Light Installation
-Bushwacker does not offer pre-cut splash guards.
Recommended yes
Comments: Most websites list this product stating no drilling and no cutting. You will find that you will be doing both. Not blaming Bushwacker but the advertising from vendors is wrong. Bushwacker needs a better solution for LED amber lights, as mentioned before if lights go out there is no way to get to them without a uninstall/re-install of fenders. I contacted Bushwacker and recommended they sell the splash guards /shields pre-cut, to make for a cleaner speedier install. Still look and work great.
Price $502
Pros Well engineered.
Straight forward install.
Fairly rigid and durable.
Looks great.. With the right tire combo.
Lots of coverage.
The flares are a "system" that needs installed correctly to ensure proper fit and performance.
Cons Plastic parts could use more attention to trimming.
Relies on two sided tape to perform properly.
Ray Charles must have drilled the holes on my rear passenger flare. The holes were difficult to align.
The other three flares lined up perfectly.
Recommended yes
Comments: Well engineered.
Lots of coverage.
Summary:
Well Engineered
Durable
Easy to install
Looks great
Recommend:
Yes
Price $500
Pros Easy to install, look great, give additional clearance, great protection from rocks and mud.
Cons none
Recommended yes
Comments: These flares look great on a TJ and give added clearance. They offer plenty of protection from rocks and mud. Easy to install if you take your time and read the directions.
Price $500
Pros Great look and coverage, super easy to install if you download pics from Bushwacker
Cons Online instructions are better
Recommended yes
Comments: The Bushwacker Flat Style Fender Flares are super easy to install if you've done at least 1 install prior. The first install is tricky and lengthy due to the instructions. I recommend downloading a color copy off the Bushwacker site since the ones in the box are barely readable. I did an OK job on mine but installed another set on my buddies Jeep and it took half the time and looks amazing. I fixed mine afterwards by loosening the screws under the flares and having my friend push in on the flares as I tightened the screws. However, if you can read and follow directions its a pretty simple job..took me about 6 hours the first time and 3 hours the second time. Highly recommend this product. Don't cut the splash shields to short!!!!!! Can always take more off...can't put back once cut!!!!
41 - 60 of 65 Posts
