Ok so i got my calipers in for the 8.8 rear end that i am building up to fit under my rig. These are some massive 2 piston guys. Last time i checked, The stock fronts in my 89 are single piston calipers. I figure that i will drive around and if my rears seem a bit grabby try to adjust the proportioning valve. I have read about guys using the proportioning valve from a ZJ. Is that a bolt on situation, and is it just a un bolt brake line rebolt, and bleed brakes? Or is it possible to adjust the stock valve?
