1 - 8 of 8 Posts
94 cherokee
brake pedal goes straight to the floor
theres no leak in the brake lines
i have new brake pads and calipers
and plenty of brake fluid
bled the brakes
But they dont work......help? :confused:
the brake booster have something to do with it?
Nope. You can have a totally non-functional booster and still have normal brakes. (The pedal pressures you will have to exert will be MUCH higher with a defective booster, but the pedal will NOT be squishy nor will it fall to the floor under pressure.)
Were the brakes like that before you changed the other hardware? If so, its the seals in the master cylinder. The fluid is flowing right around them and not being pushed into the lines. The cylinder is not to hard to change but you will have to bleed everything thoroughly again.
Discussion Starter · #8 ·
yeah they sucked but seemed like they got better after i bled them and now back to being **** again
1 - 8 of 8 Posts
