221 - 233 of 233 Posts
Discussion Starter · #221 ·
More exhaust...moving to the rear:
The old ladder bar attachment was in the way and had to be cut off - I'm going to pull the axle later and cut the rest of it off
Automotive tire Motor vehicle Automotive exterior Gas Rim
Done:
Automotive tire Bumper Automotive fuel system Rim Gas
This was the perfect tool for the job:
Tool Asphalt Toy Road surface Saw
Some of the horrible brake lines that the previous owner rigged up...I had to drop them to get them out of the way
Wheel Tire Automotive tire Tread Vehicle
This is where he added an extra leaf - I'm guessing because of axle wrap.
Wood Gas Automotive tire Lumber Grass
Starting the tube over the axle:
Automotive exhaust Gas Nickel Bicycle part Metal
Everything is tacked together in front of the muffler:
Tire Automotive tire Wheel Vehicle Motor vehicle
Muffler:
Plant Wheel Tire Automotive tire Vehicle
Over the axle:
Automotive tire Motor vehicle Automotive exhaust Vehicle brake Automotive exterior
Automotive tire Vehicle brake Bicycle part Motor vehicle Engineering
Nice exhaust hangers.
if you do one more mod and exit between frame and spring to the side you eliminate 90% or more of the fumes jumping in the back, and never munched off road.
Reactions: StanF
Discussion Starter · #225 ·
Just curious, why the double mount for the exhaust? (Both sides)
Just for better support. The inlet on the muffler is offset, so there may be some twisting forces. The pipes are very close to the crossmember and tub, so I wanted to (hopefully) prevent them hitting. Also, the rubber isolators will stretch over time, so having an extra isolator will help that too. It may not help or be necessary, but it was pretty easy to do
Discussion Starter · #227 ·
Thanks for the nice comment on the exhaust hanger 🍻
Like this? This is my 95 YJ - I had to exit the tailpipe there because of my Genright tank:
Tire Wheel Vehicle Automotive tire Tread
Wheel Tire Vehicle Automotive tire Motor vehicle
Basically, yes.
i’ll shoot a pic later.
After 15 months parked I’m finally pulling the blown transmission and rebuilding my spare.
Reactions: StanF
Discussion Starter · #229 ·
Still knocking out the exhaust details...
I'm using the stock YJ tailpipe hanger, which is rusty.
Automotive tire Bumper Wood Automotive exterior Gas
I don't know if any of you have used Evapo-Rust, but I've had good luck with it.
Rectangle Gas Cuisine Packing materials Tobacco
This is after a few hours.
Automotive tire Font Gas Wood Auto part
I cleaned up these two areas with a scratch wheel. No picture, but they got paint.
Automotive tire Font Gas Wood Composite material
Removed for welding and painting:
Road surface Automotive tire Asphalt Automotive exterior Pipeline transport
Trying this for the first time. At $13/can, it's a little pricey.
Tin Automotive tire Tin can Plant Drink
Primed. No picture, but it got the top coat afterwards
Land vehicle Wheel Tire Car Vehicle
I should get the other parts welded and painted soon. Hopefully, the exhaust will be finished and installed on the Jeep this weekend.
Discussion Starter · #230 ·
More exhaust work:
Mid pipe is fully welded, cleaned and primed:
Mid pipe after top coat:
Tailpipe primed (it was later painted, no picture):
Insulation wrap materials. I've never used any of this stuff before.
I just wrapped some targeted areas. This wrapped area is adjacent to the starter. You can also see one of the O2 ports that I added. I stopped wrapping at the O2 port because it was going to be complicated to get around that area.
Wrapping such small areas was pretty easy.
Oil Pan wrap. The pipe is closer to the pan than it looks in this picture:
Starter wrap:
After the front pipe was installed, I wrapped another area on the other side of the O2 port. I wanted to protect the starter a little more.
More exhaust work:
Very nice exhaust work!
I know it's after the fact, but I might have shoved some paper into the ends of the pipes to keep the paint out. Not totally sure if it matters much, but just something I noticed. 🙂
Discussion Starter · #233 ·
Good suggestion - I didn't really worry about overspray into the pipe at all, and I didn't do any prep work on the inside of pipes. Anything that got in there would likely have trouble sticking. Any paint in the pipes will probably just blow out or burn off pretty quickly.
