1 - 20 of 27 Posts
Eat, Sleep, Jeep
Hey guys, with it a bit chilly out and us having a ton of threads on heat issues, I thought I'd roll the good ones up into one thread for easier searching. If you know of another one or a heat cure, list em up.
Chevy blower motor install
This is replacing your stock blower motor with one from a Blazer (about 15 bucks new) for appx 5x airflow
http://www.jeepforum.com/forum/showthread.php?t=69254
http://www.jeepforum.com/forum/showthread.php?t=496120
http://www.jeepforum.com/forum/showthread.php?t=493878
http://www.jeepforum.com/forum/showthread.php?t=489133
Sentinal's Heat Deflectors
I put these in every YJ I've had, best heat mod ever, with or without the Blazer motor upgrade. Not sure if he's still making them though
http://www.jeepforum.com/forum/showthread.php?t=122052
http://www.jeepforum.com/forum/showthread.php?t=481757
http://www.jeepforum.com/forum/showthread.php?t=244001
Heater/vent vacuum connections to get flaps opening / closing correctly
Top thread in progress on how the vac system can open, close the right flaps, producing more airflow
http://www.jeepforum.com/forum/showthread.php?t=499877
http://www.jeepforum.com/forum/showthread.php?t=503330
http://www.jeepforum.com/forum/showthread.php?t=496457
http://www.jeepforum.com/forum/showthread.php?t=494427
http://www.jeepforum.com/forum/showthread.php?t=488902
More airflow using hood scoop on cowl vent
http://www.jeepforum.com/forum/showthread.php?t=484359
Hard and Soft top insulating ideas and write ups
http://www.jeepforum.com/forum/showthread.php?t=333017
http://www.jeepforum.com/forum/showthread.php?t=448034
http://www.jeepforum.com/forum/showthread.php?t=500882
http://www.jeepforum.com/forum/showthread.php?t=490710
http://www.jeepforum.com/forum/showthread.php?t=481873
http://www.jeepforum.com/forum/showthread.php?t=481958
http://www.jeepforum.com/forum/showthread.php?t=479276
Additional aux heaters for rear seats and supplimental heat
http://www.jeepforum.com/forum/showthread.php?t=503052
http://www.jeepforum.com/forum/showthread.php?t=491846
Thermostat, Waterpump, Coolant, Heater Core related info to get max heat
http://www.jeepforum.com/forum/showthread.php?t=502814
http://www.jeepforum.com/forum/showthread.php?t=502974
http://www.jeepforum.com/forum/showthread.php?t=471873
http://www.jeepforum.com/forum/showthread.php?t=468565
http://www.jeepforum.com/forum/showthread.php?t=499777
http://www.jeepforum.com/forum/showthread.php?t=496962
http://www.jeepforum.com/forum/showthread.php?t=503185
http://www.jeepforum.com/forum/showthread.php?t=219329
Cracking windows in butal cold temps
http://www.jeepforum.com/forum/showthread.php?t=503458
http://www.jeepforum.com/forum/showthread.php?t=479133
Trans issues in the cold
http://www.jeepforum.com/forum/showthread.php?t=497517
http://www.jeepforum.com/forum/showthread.php?t=499594
http://www.jeepforum.com/forum/showthread.php?t=497020
http://www.jeepforum.com/forum/showthread.php?t=497265
http://www.jeepforum.com/forum/showthread.php?t=496489
http://www.jeepforum.com/forum/showthread.php?t=428139
Shrinking top, snow care for soft top
http://www.jeepforum.com/forum/showthread.php?t=265888
http://www.jeepforum.com/forum/showthread.php?t=364680
http://www.jeepforum.com/forum/showthread.php?t=497286
http://www.jeepforum.com/forum/showthread.php?t=493284
http://www.jeepforum.com/forum/showthread.php?t=482807
Rear defroster wiring
http://www.jeepforum.com/forum/showthread.php?t=490733
http://www.jeepforum.com/forum/showthread.php?t=478093
http://www.jeepforum.com/forum/showthread.php?t=459949
http://www.jeepforum.com/forum/showthread.php?t=332751
http://www.jeepforum.com/forum/showthread.php?t=221257
Windshield thawing without cracking it when cold
http://www.jeepforum.com/forum/showthread.php?t=493071
http://www.jeepforum.com/forum/showthread.php?t=495709
http://www.jeepforum.com/forum/showthread.php?t=345938
Hard starting in the cold
http://www.jeepforum.com/forum/showthread.php?t=503558
http://www.jeepforum.com/forum/showthread.php?t=492690
Richmond 88 YJ said:
Hey guys, with it a bit chilly out and us having a ton of threads on heat issues, I thought I'd roll em all up into one thread for easier searching. If you know of another one or a heat cure, list em up....
[/URL]
Now this would make a great permanent thread listed above so it does not get lost!
:2c:
Got my eye on you.....
I think this does qualify as a STICKY for at least the rest of the winter. Great thread Richmond :cheers2:
Wow. Great work. It is efforts like this that keep this forum not only a great place to visit but a phenomenal reference tool for all as well.
Thank you Thank you Thank you
I guess I should be thankful our winters rarely stay in the single digits for long. I can't even run my heater turned all the way up. You could pop corn in my jeep. And that's with a soft top.
I've read around alot, can you do the blazer blower motor upgrade on a 1994 Wrangler? One of the websites said it had never been attempted.
Thanx for the great info. First winter w/soft top. 91 has hard top. Gets a little chilly here in Ill Dec-Feb. Especially like the support for the front of the top. Tks again.
These are the all in one threads that we need! Thank You for the great work Ernie! Fine Job!
Now that is some good information! This is not a sticky ? Saves me a bunch of bookmarks !
GREAT JOB THANKS FOR ALL THE WORK :congrats:
Oops, my bad, it is a sticky. ok ok so I am new! and it is still 70-80degrees outside...
OK grats on the thread and grats for making it a sticky
BUMPED to the top for the cold weather is uppon us.
there is also a new thing in the new 4wd cataloge, it goes in place of the out let for the heat under the dash, it gets rid of the vents that point towards the shifter, and brings the other outlet down and pointed towards the driver and passenger's feet. The part number is #5618
i just did this upgrade, and WOW!! it blows and heats the car so much faster (almost hotter in my opinion) and quieter! i read it on the forums many times about how great the improvement of the air flow was with this upgrade, but you have to do it yourself to believe it. its even quieter (i woulda been happier with it just being quiet and just slightly warmer) but i replaced my heater blower motor, and the heater core since i had it all apart.
took me about 4 hours to cut pull the old parts, cut the hole wider, and install everything back into place.
just be sure you have the right tools to cut the firewall, thats what took most of my time cause i started with a saw and then broke the blade and ended up having to use a dremel and went through 3 grinding attachments.
if anyone has any questions i'd be happy to try to help with this mod.
Eat, Sleep, Jeep
Discussion Starter · #18 ·
4 hours.. Did you have AC? or just take your time?
i didn't have the correct tools for the job, so it took me longer to cut the hole wide enough. plus i had to go get things like the heater core and my parts store isn't right around the corner.
so i guess you could say i took my time....no i don't have AC...unless you consider taking the top off AC ;)
Eat, Sleep, Jeep
Discussion Starter · #20 ·
Ahhh.
The reason I asked is I'm doing this this weekend and have AC (not used) but it's in the way and a PIA. Was just trying to guesstimate time required.
1 - 20 of 27 Posts
