Day I bought it
last month
last month
Were you able to keep the factory cruise control with the swap? I think I see the servo for it behind the aluminum tank on the inner fender.
Very observant. Yes, I kept it intact. Problem is the damn steering wheel wont activate it after the swap. None of the cruise switches on the wheel do anything. Still looking for advice on how to get those working before I can actually use it.Were you able to keep the factory cruise control with the swap? I think I see the servo for it behind the aluminum tank on the inner fender.
I wonder if it has to do with re-wiring for the swap. Maybe something got missed. I am sure you have already thought of that. That is something I would like to keep on mine if I did a swap. It comes in handy on longer drives at freeway speed for sure.Very observant. Yes, I kept it intact. Problem is the damn steering wheel wont activate it after the swap. None of the cruise switches on the wheel do anything. Still looking for advice on how to get those working before I can actually use it.
I was talking with someone else doing a swap and they had the same issue with the wheel controls not working. They ended up adding an aftermarket unit on that one. Not sure if this is a common thing or not.I wonder if it has to do with re-wiring for the swap. Maybe something got missed. I am sure you have already thought of that. That is something I would like to keep on mine if I did a swap. It comes in handy on longer drives at freeway speed for sure.
Did you use a drive by cable throttle body then? I have heard the DBW throttle bodies can be switched out for older DBC as long as the ECM for the engine is programmed to accept the inputs from a TPS. Or something along those lines.
