Product Information
4.0L 6-CYL:
1991-05 WRANGLER, 1991-01 CHEROKEE, '93-01 GRAND CHEROKEE, 1991-92 COMMANCHE: Banks TorqueTubes is a streamlined exhaust manifold designed to optimize exhaust flow and engine efficiency. Because the stock manifold's flange does not align squarely with the ports, flow is restricted. TorqueTube corrects the problem with a half-inch flange that is machined dead flat, and precisely fitted to the port pattern. You can hear the difference in the plusher, healthier exhaust note.
Unlike the stock, failure-prone exhaust manifold, Banks TorqueTube is built of heavy, 409 stainless steel to weather a lifetime of heat, stress and abuse. The flange, welded to the tube assembly on both sides, will never crack or separate. The gasket is made of SMI 900, a material that stands up to super-hot temperatures.
Bolts right on. Optional head pipe available for the best flow.
2.5L 4-CYL
1991-02 WRANGLER: The Banks TorqueTubes assembly for the 2.5L Wrangler provides nearly identical engineering innovations and benefits as the TorqueTubes for the 4.0L 6-cylinder Jeeps: bulletproof construction … precision fit of the dead-flat half-inch flange to the port pattern … imperviousness of the flange to cracking and separating … and the easy, bolt-on design. Includes an extra-thick gasket (not shown) that stands up to super-hot temperatures.
Price | $1000 |
Rating | 4 |
Average Price | $399.07 |
Manufacturer | Banks |
Recommended | Yes: 69 / No: 11 |
4.0L 6-CYL:
2.5L 4-CYL
