1 - 19 of 19 Posts
Rating 4
Pros Cheap, looks like Banks reject
Cons Tight fit, fat ears, tough to get to one stud
Recommended yes
Comments: I installed this in April, so far so good! Nice sound Great price! No fabrication needed (by my chinny chin chin). Ears are large and barely mated with intake.
I am very happy so far!!!
Price $225
Pros Sounds real mean. Mildly sharper throttle sponse which a big boost on high end performance
Cons Pain in the rear to install
Recommended yes
Comments: I'm not sure if this header is the one I got, as I got them off ebay. Mine is 1 5/8" stainless steel. The high end performance increase and sound were very obvious. Definitely a good investment, especially since the stock exhaust manifolds are notorious for cracking
Price $100
Pros Repairable with expansion joints and stainless...
Cons none
Recommended yes
Comments: This is your generic stainless exhaust manifold with expansion joints commonly found on EBAY for a reasonable price and included new gasket and exhaust donut.
Price $140
Pros better design, stronger metal, GREAT PRICE
Cons cant get to my door quick enough
Recommended yes
Comments: awesome product for a great price. if you still have the stock manifold, then replace with this immediately
Price $139.99
Pros can't beat the price and well made
Cons ***** to put on...have the grinder handy
Recommended yes
Comments: great replacement for the cracked exhaust manifold. not bad to put on, but needed to grind part of the intake manifold for these to fit on my 99 xj.
sounds great with the hi-flow cat and flo-pro exhaust.
Price $160
Pros works well, cheap, sounds cool
Cons Need to modify intake manifold to make it fit
Recommended yes
Comments: I installed this on my jeep shortly after buying it. Replaced cracked stock manifold. In order to make it fit I had to grind a hole between #4 and #5 tubes on my intake manifold, also had to grind outside tabs a tiny bit. This header sounds awesome. I can't really compare it to a stock manifold performance wise as my factory one was cracked. If this on breaks I will try the ebay manifold with the expansion tubing.
Price $150
Pros price is great. comes with gasket
Cons some grinding off the intake manifold on some vehicles
Recommended yes
Comments: great replacement over stock manifold. some may notice some gains in the ponies
Price $149.99
Pros Sounds amazing, increased throttle response and more torque.
Cons Hard to install. LOTS of grinding involved.
Recommended yes
Comments: I had the infamous cracked manifold problem associated with the 4.0 so I finally pulled the trigger and bought the APN header. It came very quickly and had all of the parts in the box. I took my time labeling everything during the tear down so that everything would go together smoothly. And it did, all except for the intake manifold, which I had to grind around 1/8th of an inch off of the outside of each port in order to get the thing to fit. Oh and DEFINITELY do step 2, even if you feel like you can fit the bolts in after the intake is on....you can't.
Price $165
Rating 5
Pros Cheap, Great quality and came with a gasket
Cons None to speak of
Recommended no
Comments: After reading a bunch of reviews and searching the web I finally decided on this one. I had the money for one of the Bigger named brand ones, but went with this. I couldn't be more happier. It was a decent install, had a little difficulty getting it into place (just like any header), but once I found the sweet spot popped right in. And, with the money I saved i got all new pipe front to rear and a new Thrusher muffler to boot.:2thumbsup:
Price $150
Pros Drop in installation. Bolted right up with no problems
Cons None
Recommended yes
Comments: This was my first major header install. It came with the gasket and hardware. It took my an afternoon to install, and everything bolted right up with no modifications. The welds look hefty and unlikely to crack.
The sound around 2500-3000 RPMs is intoxicating. I had hoped my gas mileage would get better, but I doubt it will -- the sound makes me want to step on the skinny pedal.
Can't say if there's many more ponies there, since my old manifold suffered from the 4.0 crack..
Price $180
Pros slight power gain, good exhaust note
Cons Had to do some grinding to fit
Recommended yes
Comments: Welds cracked after 6000 miles, Rock Auto made good with no hassell, but had to pay $33 return shipping we'll see if the 2nd one holds up better. I have good engine and trans. mounts, exhaust not in a bind and was mildly offroaded, looked liked sorry Chinese welds to blame.
Price $179.85
Rating 1
Pros Cheap, looked ok at first inspection
Cons Cheap, ports did not line up with gasket and head, had to hammer/dent the # 6 tube to clear the intake. Cracked after 6 months
Recommended no
Comments: Bought this from amazon to replace my cracked factory manifold. I had rewelded it and it lasted another 10 years before it cracked again. I bought this one thinking it looked like a decent replacement. Once I got it, I set a new fel-pro gasket up to it and all but two of the ports did not line up. Most were off by 1/8in or more! Other than that, it looked ok. I took a die grinder and fixed the ports best I could. I didnt have enought time to return it for another as I had the jeep torn down already. I installed it and had to hammer the #6 tube to clear the intake. Cheap POS!
Here I am, probably 6-8 months after installing it and it has cracked! Also, this so called "stainless steel" started rusting after about a month.
STAY AWAY!
Price $200
Pros Added some bottom end torque.
Cons Had to make them myself. Also had to notch out and plate the passenger side frame to get them to fit and for clearance issues.
Recommended yes
Comments: I wasn't going to pay what everyone out there that had them, which was very few so that's why I made them myself.
1 - 19 of 19 Posts
