1 - 4 of 4 Posts
Hi everyone!
Couple months ago I bought a 1997 Grand Cherokee Laredo 4.0 242 transfer case, 42RE, D30/D35 with LSD.
My double cardan started to make terrible noise today, so I took the whole front drive shaft off and I am trying to figure out if I should try to rebuild it (was told it's not the easiest thing to do, and I don't really have enough tools at home to do so), have it rebuilt, or should I replace the whole thing. I am a little confused by the amount of different drive shaft configurations. Looking by part number I found on this forum, one that is identical to mine costs $450-$700. The one pictured below, with a flange in the front is half the price, but the description says its meant for 249.
My question is: will this drive shaft fit my Jeep, after removing the flange (?) from the front? If not, can I make it fit by changing the differential flange? or can I just change the slip yoke from my old drive shaft?
Office supplies Writing implement Font Stationery Tool
My current drive shaft:
Wood Gas Bumper Auto part Metal
Wood Gas Engineering Auto part Composite material
Thank you very much for any help.
Not at all hard to rebuild with basic tools. Remove the clips and pound. Search for youtube u-joint replacement.
If that doesnt interest you take it to a shop and they will rebuild, Im guessing a couple hundred bucks.
I cant confirm or deny but I doubt theres any interchangability.
Hi everyone!
93 to mid 95 they still used U joint shafts with a 249. Mid 95 through 98 they had Rzeppa(CV) shaft for smoother operation with the 249.
Mid 95 to early 96 was a mixed bag.
You want the u joint shaft not the CV shaft.
You'll need to make sure the length is correct too.
That flange adds quite a bit of length to the shaft, if you remove it and install using just the U-joint the shaft may end up being too short.
Reactions: HighLonesome
1 - 4 of 4 Posts
