*ALL READ* XJ Suspension Kit Options - Enjoy!!!
40425 Views 74 Replies 38 Participants Last post by  Shanker67
*All Available XJ Suspension Systems*​
Alright so heres the story, I realized that there are a lot of posts on this forum asking What kind of kit should I get? Where should I get it from? What are the Prices? So I decided that I should sit down and put a list together of what is out there and roughly what they come with. Well it turns out that it took me about three sittings to get it all finished up and im sure that I didn't finish everything. So I hope that you guys enjoy this and please by all means let me know if I have something wrong or if im missing a lift. Thanks for putting on a great forum guys and I hope that this helps out some people.
*Please Note*
1. The available tire clearance for each lift does not include any trimming that may be done. Those suggested sizes are for stock fenders and you have the potential to get a much bigger tire size if you do a little trimming.
2. The links provided are not necessairly the best available prices but instead links to give an example as to what the exact lift is that your looking for.
3. For all Jeep Forum members there is a coupon code that we can use while shopping at Jeepin Outfitters, this code is JFM05
How To Install A Lift On A XJ
http://www.jeepforum.com/forum/showthread.php?t=404101
How To Install A TC Drop On A XJ
http://www.jeepforum.com/forum/showthread.php?t=405578
All Available Shackle, Coil Spacer, And Budget Options
http://www.jeepforum.com/forum/showpost.php?p=3556446&postcount=1
Everything You Need To Know About A Leaf Conversion
http://www.naxja.org/forum/showthread.php?t=27835
2-2.5 Inch Lift Options
RE6160 XJ 2" Budget Boost w/shocks
Tire Clearance: 30x9.50
Includes: Break Lines, AAL, Spacers, and Shocks
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=112
OME 2" Suspension Kit, Cherokee, 1984-01
Includes: Bumpstops, Full Leaf Packs, Coils, Shocks, JKS Quicker Disconnects
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=645
Superlift 2.5" Suspension lift, Jeep XJ Cherokee
Includes: Coils, Lower link arms, AAL, and Shocks
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=781
Rustys 2" XJ AAL Kit
Includes: Coils, AAL, and Shocks
http://rustysoffroad.com/mm5/mercha...s&Product_Code=200AL&Category_Code=sus_xj_kit
Rough Country 1.5" Suspension Kit
Includes: Coils, Shackles, and Shocks
http://www.roughcountry.com/jeep_xj_1.html
Rock Lizard Fabrications 2" AAL Kit
Includes: Coils, Long AAL, Leaf Spring Clamps, Center Pins, and U-Bolts
http://www.rocklizardfabrications.com/lizard_lift_kits.htm
Rock Lizard Fabrications 2.5" Leaf Pack Kit
Includes: Four Leaf Spring Pack, Coils, Long AAL, Spring Isolators, Spring Clamps, Center Pins, and U-Bolts
Skyjacker 2 in. Poly Value Kit
Includes: Poly Spacers, Bumpstops, Shackle and Nitro Shocks
http://www.4wheelparts.com/PDT55375.aspx
Rustys 2" Budget Boost w/Shackle
Includes: Poly Spacers, and Shackle
http://rustysoffroad.com/mm5/mercha...s&Product_Code=XJ-B1&Category_Code=sus_xj_kit
Rustys 2" Budget Boost w/AAL
Includes: Poly Spacers, and AAL
http://rustysoffroad.com/mm5/mercha...s&Product_Code=XJ-B3&Category_Code=sus_xj_kit
3-3.5 Inch Lift Options
RE6030 XJ 3.5" SuperFlex kit w/leafs
Tire Clearance: 31x10.50
Includes: Gen2 Disconnects, Coils, Bumpstops, Leaf Spring Pack, Rear break line, U-Bolt Kit, and LCA
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=115
RE6010 XJ 3.5" SuperFlex kit w/aal's
Includes: LCA, Coils, Bumpstops, AAL, and Shocks
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=120
RE6025 3.5" XJ Super Ride w/ Rear Springs
Includes: LCA, Full Leaf Packs, Coils, and Rear Break Line
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=219
RE6020 3.5" XJ Super-Ride Kit
Includes: LCA, AAL, Coils, and Rear Break Line
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=218
OME 3" Suspension Kit, Cherokee, 1984-01
Includes: Shocks, Full Spring Packs, Coils, and JKS Quicker Disconnects
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=429
Rustys 3" Spring Pack Kit
Includes: Coils, Full Spring Packs, Break Line Relocation Kit, and Shocks
http://rustysoffroad.com/mm5/mercha...s&Product_Code=300SP&Category_Code=sus_xj_kit
Rustys 3" XJ Add-A-Leaf Kit
Includes: Coils, AAL, Break Line Relocation Kit, and Shocks
http://rustysoffroad.com/mm5/mercha...s&Product_Code=300AL&Category_Code=sus_xj_kit
Rough Country 3" Suspension Kit, Full Spring Pack
Includes: Coils, Full Spring Pack, and Shocks
http://www.roughcountry.com/jeep_xj_3.html
Rough Country 3" Suspension Kit, AAL
Pro Comp 3" Suspension System
Includes: Coils, AAL, Break Lines, LCA, and Adjustable Shocks
http://www.4wheelparts.com/PDT1764.aspx
Includes: Coils, AAL, Break Lines, LCA, and Non Adjustable Shocks
http://www.4wheelparts.com/PDT1566.aspx
Rancho 3 in. Suspension Kit with RS5000Shocks
Includes: Coils, Full Leaf Pack, and Shocks
http://www.4wheelparts.com/PPT3657T5491.aspx
Skyjacker 3 in. Standard Kit w/AAL
Includes: Coils, AAL, and Hydro Shocks
http://www.4wheelparts.com/PDT54900.aspx
Skyjacker 3 in. Standard Kit w/ Full Spring Pack
Includes: Coils, Full Spring Pack, and Hydro Shocks
http://www.4wheelparts.com/PDT55240.aspx
Full Traction 3.5" Kit
Includes: Coils, Quick Disconnects, Rear Break Line, Dual Rear Leaf Inserts, and Control Arms
http://www.full-traction.com/detail.php?MODELID=4&MAKEID=1&TYPEID=1&PRODUCTID=97&NOTES=20
Warrior 3" Suspension Kit
Includes: Shocks, Shackles, Coils, AAL, Sway Bar Link, Tie Rod Bracket, and LCA
http://www.discountjeepparts.com/pr...18109?osCsid=b1ddede67daec307cc3b0a2381eb6115
Rock Krawler 3" Suspension Kit
Includes: Coils, AAL, Adj Front Trac Bar, Trac Bar Relocation Bracket, Drop Pitman Arm, Sway Bar Discos, and U Bolts
http://www.tellico4x4.com/product_info.php/cPath/3601_3603_3608/products_id/28396
Black Diamond 3" Suspension Kit w/ AAL
Includes: Coils, Shocks, Full AAL's, and LCA's
http://www.4wheelerssupply.com/catalog/product_info.php/products_id/1581
4-4.5 Inch Lift Options
RE6130 XJ 4.5" SuperFlex kit w/leafs
Tire Clearance: 32x11.5
Includes: Coils, Full Spring Pack, Bumpstops, Front Track Bar, LCA, Rear Break lines, and RE Gen2 Disconnects
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=113
RE6111 XJ 4.5" SuperFlex kit w/AAL
Includes: Coils, AAL, Bumpstops, Front Track Bar, LCA, and Break Lines
http://www.jeepinoutfitters.com/scripts/prodList.asp?idCategory=62
Superlift 4" RockRunner lift kit, Jeep XJ Cherokee
Includes: Coils, Full Spring Pack, Shocks, Upper and Lower axle links, Front Track Bar, and Quick Disconnects
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=783
Superlift 4" Standard lift kit, Jeep XJ Cherokee
Includes: Coils, Full Spring Pack, Shocks, Front Track Bar, Upper and Lower axle links, and Quick Disconnects
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=782
Rustys 4.5" XJ Spring Pack Kit
Includes: Coils, Full Spring Pack, Shocks, LCA, Break Lines, Front Track Bar, TC Drop Kit, and Front Sway bar Extensions
http://rustysoffroad.com/mm5/mercha...ys&Product_Code=405K&Category_Code=sus_xj_kit
Rustys 4.5" XJ Add-A-Leaf Kit
Includes: Coils, AAL, Shocks, Rear Shackles, LCA, TC Drop, Brake Lines, and Sway Bar Extensions
http://rustysoffroad.com/mm5/mercha...s&Product_Code=405AL&Category_Code=sus_xj_kit
Rough Country 4.5 Suspension Kit w/AAL
Includes: Coils, LCA, TC Drop, Front track bar drop bracket, Swaybar links, Brake lines, Shocks, AAL, and Shackles
http://www.roughcountry.com/jeep_xj_4.html
Rough Country 4.5 Suspension Kit w/ Full Spring Kit
Includes: Coils, LCA, TC Drop, Front track bar drop bracket, Swaybar links, Brake lines, Shocks, and Full Spring Pack
Fabtech 4 in. Performance Kit
Includes: Coils, Rear AAL, Rear Shackle, Extended Sway Bar Links, and Shocks
http://www.4wheelparts.com/PPT1906T5491.aspx
Rock Krawler 4.5" Short Arm Flex Lift Kit
Includes: Leafs, Coils, Double Adj LCA'a, Sway Bar Discos, and Rear Shims
http://www.jackit.com/manufacturer/rockkrawler/jeep_xj_sa.htm#xj45sa
Rock Krawler 4.5" X Factor Short Arm Kit
Includes: Leafs, Coils, Double Adj LCA'a, Sway Bar Discos, Adj Trac Bar, and Shims
http://www.tellico4x4.com/product_info.php/cPath/3601_3603_3608/products_id/24145
Rock Krawler 4.5" X Factor Plus Long Arm Kit
Includes: Leafs, Coils, High Adj LCA's, Long Arm Brackets, UTA, Adj Track Bar, Trac Bar Relcoation Bracket, Break Lines, Sway Bar Discos, and Rear U Bolts
http://www.tellico4x4.com/product_info.php/cPath/3601_3603_3608/products_id/24146
5-5.5 Inch Lift Options
RE6200 XJ 5.5" Extreme Duty lift
Tire Clearance: 33x12.50
Includes: Coils, Full Spring Pack, Track Bar, LCA, Bumpstops, RE Gen2 Disconnects, and Break Lines
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=111
RE6300 5.5" XJLA Extreme Duty
Includes: Coils, Full Spring Pack, Shocks, Track Bar, LCA, Bumpstops, RE Gen2 Disconnects, Break Lines, and Long Arm Conversion
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=388
T&T Customs XJ 5.5" Y-Link Suspension System
Includes: Coils, Full Spring Pack, Shocks, Track Bar, LCA, Belly Pan, Shock Mounts, Drop Pitman arm, Unibody Bracing System, Shackles, and Sway Bar Disconnects
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=681
DPG 5" Suspension System
http://dpgoffroad.com/xjtrailgunner.htm
6-6.5 Inch Lift Options
Rustys 6.5" XJ/MJ Long Travel Suspension Kit
Tire Clearance: 34x12.50
Includes: Coils, Full Spring Packs, Shocks, Trac Bar, JKS Sway Bar Disconnects, and Break Lines
http://rustysoffroad.com/mm5/mercha...s&Product_Code=605LT&Category_Code=sus_xj_kit
Rustys 6.5" XJ Spring Pack Kit
Includes: Coils, Full Spring Pack, Trac Bar, UCA, LCA, Break Lines, JKS Sway Bar Disconnects, and Shocks
http://rustysoffroad.com/mm5/mercha...ys&Product_Code=605K&Category_Code=sus_xj_kit
Rough Country 6.5" Suspension Kit
Includes: Coils, Full Spring Pack, UCA, LCA, TC Drop Kit, Track Bar, Sway Bar Disconnects, Pitman Arm, and Shocks
http://www.roughcountry.com/jeep_xj_6.html
Skyjacker 6 in. Rock Ready Kit
Includes: Coils, Full Spring Pack, Pitman Arm, and Hydro Shocks
http://www.4wheelparts.com/PDT54902.aspx
Full Traction 6" Kit
Includes: Coils, Full Spring Pack, Long Arms, Quick Disconnects, Track Bar, and LCA
http://www.full-traction.com/detail.php?MODELID=4&MAKEID=1&TYPEID=1&PRODUCTID=98&NOTES=9,10
Rock Krawler 6.5" X Factor Plus Long Arm
http://www.tellico4x4.com/product_info.php/cPath/3601_3603_3608/products_id/24151
8 Inch Lift Options
Skyjacker 8" Rock Ready Kit
Tire Clearance: 36
Includes: U-bolts, Double Flex lower control arms, Front brake hoses, Rear brake hoses, Dropped pitman arm, New control arm mount brackets and frame, Rear sway bar end links, Rear shackles, Front bumpstop spacers, Rear bumpstop spacers, Flex series upper control arms, Front sway bar links, Front track bar with steering stabilizer, Rear leaf springs, and Dana 30 cradle and brackets
http://www.4wheelerssupply.com/cata...Sized&osCsid=1db1ec9436c3063021cc1596c1c189fc
Rock Krawler 8" X Factor Plus Long Arm
Tire Clearance: 36
http://www.tellico4x4.com/product_info.php/cPath/3601_3603_3608/products_id/24152
Rock Krawler Super 8.0" Plus with Rear Coil Over Conversion
Tire Clearance: 36
Includes: Double Adj LCA'a, Long Arm Brackets, UTA, Torque Arm Bracket, Adj Trac Bar, Trac Bar Relocation Bracket, Rear UCA, Rear 4 Link Mounting Cable, Coil Over Mounting Brackets, Break Lines, Rear Shocks, and Front Quick Discos
http://www.tellico4x4.com/product_info.php/cPath/3601_3603_3608/products_id/24087
Rustys 8" XJ Long Travel Suspension Kit
Tire Clearance: 36
Includes: Leafs, Coils, Shackles, Shocks, Drop Pitman Arm, Trac Bar, JKS Discos, and Front ans Rear Break Lines
http://rustysoffroad.com/mm5/mercha...s&Product_Code=800LT&Category_Code=sus_xj_kit
Thanks For Reading and I hope this Helps
-Kyle
See less See more
1 - 20 of 75 Posts
dang i left out rock lizard stuff i will add later tonight
-kyle
alright i will add those lifts probably tomarrow, i will also be updating the pricing as things go along
and i will mention about the stock flares and such
thanks for the sticky add:thumbsup:
-kyle
thanks for the feedback guys i will be adding those lifts asap but im currently hangin out with my girlfriend so i am a bit tied up
but anyway when i was looking for links for the lifts i wasnt necessairly looking for the best price instead of just finding the product
thanks for the imput
-Kyle
eric that is an excellent idea, i was thinking about that very thing when i was listing the lifts and i figured that i should ask jason before doing it, but then i got lazy and just did it...but anyway those prices will be gone by the end of the night
thanks for the suggestions all:cheers2:
-Kyle
alright so ive done some editing to my thread
1. No More Prices
2. A "Please Note" Section
3. Added Rock Lizard Fab, Rancho, and Skyjacker
will be adding more lifts tonight
-Kyle
dude in an xj said:
Typing error, forgot shackles and front bumpstops
done thanks:thumbsup:
-Kyle
dude in an xj said:
typing error
Also, don't forget that Rustys makes two 2" Budget Boosts........
1. Spacers and AAL
2. Spacers and Shackle
done :thumbsup:
thanks for all the help guys:cheers2:
-Kyle
added warrior and full traction to the list:thumbsup:
-Kyle
thanks for the responses guys, i will put somthing together as far as a seperate page just for shackles tomarrow, if you guys have any ideas feel free to pot them hre and i will add them in the section.
glad that its helping people, suggestions are open as always:thumbsup:
-kyle
SkyHigHXJ said:
the 8" kits, SJ, Rockkrawler, etc. :p
lol ya i figured some of you guys would want to see those 8in kits, ill add them tomarrow with the schackle section
-Kyle
SkyHigHXJ said:
no rush lol, i was just buggin you cause i member someone way back saying why didnt he put the 8" kits up. Awesome list though man :thumbsup:
ya well im working today, but tomarrow i will add them(i like to make the list as complete as possible :) )
-kyle
added Rock Krawler suspension kits and the 8" Skyjacker Kit, will be working on the Shackle section in a bit
-Kyle
L8 APEKS said:
I'm shopping for a Jeep right now, and also researching what suspension/tire combo will suit my needs the best. This thread has been the most informative thread on the XJ board. Why is it on page 3?!?!
Sticky please, this is page 1 material! :)
Thanks for the appreciation:thumbsup: its actually posted in the FAQ section of the forums under "lifts" so you can find it there, but ya im glad it has helped you and i hope it can help many others in the future. O and one day i hope that it makes it as a sticky. But for now its a regular thread, but i make it come back to the front page once and awhile when i make updates and post them.
SkyHigHXJ said:
i want that rockcrawler 8.0 rear coil convo kit so bad, anyone wanna buy my SJ rock ready double flex kit? like brand new only 5k miles on it. actually sits at 6.75 bought for 1889(deal from a friends shop, usually run for 2200 or so) will sell for 1750
i hear you man:cheers2: that is a sweet looking setup, but it is a very large amount of money that can be spent in other areas of the jeep. But i can always hope that i can win the lotto and run that coil convo kit:drool:
but again thanks guys, and im still working on the shackle section of my lift thread it should be up tomarrow:thumbsup:
-Kyle
Alright as requested i have added coil spacers/shackles to my list as a link on the top, please let me know if there is anything wrong with it or if something needs to be added.
I have also added a very good link from NAXJA on leaf conversions to my main suspension post because i figured it would be beneficial for some.
Enjoy
-Kyle
TXjeep97 said:
Are these the cheapest prices on the 'net right now? I'm days away from getting the RE 3.5" (still debating superRIDE vs superFLEX). It will mostly be for looks and mud. I also want full spring packs...
So are these the cheapest?
the answer to that question is no they are not the cheapest prices but some of them very well could be
i chose jeepinoutfitters for as much product as i could because of the fact that jason has given me aswell as many others around here excellent customer service so i thought that i would help him out by putting the majority of my links on my thread from jeepin. i would highly recommend going through jason with all of your jeep products because he backs the stuff that he sells 100% and i like having the knowledge that if anything happens to go wrong it will be taken care of asap
-kyle
well im using my phone right now so i cant look it up but i assume those are the DT 3000 shocks and i havent heard many good things about them but hey its always better when its free
-kyle
TXjeep97 said:
Not even, I had selected the RE brand ones! Crazy!
haha well ill have to check that out when i get home, sounds like a good deal if it is true
-kyle
ya i just added the 8" section, i will add the rustys once i get home. thanks for the headsup:thumbsup:
-kyle
added rustys 8inch kit:thumbsup:
again thanks for all of the posative responses guys.:cheers2:
-Kyle
1 - 20 of 75 Posts
