Air Filter
2887 Views 55 Replies 15 Participants Last post by  bob4703
Finally got the CJ back after replacing the steering column and steering shaft. Took a while to get the right one, but finally nailed it down. Now I'm looking into keeping the 304 working in top condition. Any suggestions of what oil filter and oil to use, as well as, an air filter. K&N? Is it worth the money? Any suggestions? Thank you for all the help. This forum has been amazing for all the help given so far.
41 - 56 of 56 Posts
Disclaimer:
I've run everything from sand to pummy dust, so my views may are skewed towards the worst case scenario.
IMHIO, Gauze filters (like the K&N) have no real advantage on gas engines. Gas engines don't draw enough flow at anything but high RPM WOT to see an advantage of gauze over a paper element. Being able to toss the paper element instead of servicing the gauze filter is a major advantage that outweighs the "cool factor" for me.
Diesels are another thing. They draw as much at idle as most gas motors at WOT. Their breathing needs are much more substantial. This is where the gauze filter makes it's money. Unfortunately, the engine pulls so much air that it tends to "open" up the gauze and let fine grit pass (personal experience talking here). So much of the touted advantages of the filter have been negated by it's inability to filter properly. The big intake upgrade for pre 04 Powerstrokes is the "Tymar" upgrade, which consists of a large paper filter mounted on the fender in lieu of a any of the gauze elements and/or their "cold air" intakes.
I run gauze on my quads. They only see sand which is a course medium and coupled with a sand sock, rarely need servicing. Since the stock filters were a foam oil filter anyway, the ease of servicing the former makes it a better choice for me with no loss of filtration.
A quick note on stock style air filter housings. The single funnel intake actually aids in keeping your filter cleaner longer. As the air is brought in, it picks up velocity as it runs down the snorkel. the heavier particles will tend to continue on and hit the filter in front, keeping the rest of the element cleaner. I prefer these to the open performance style housings, especially in dirtier environments, which tend to drew outside air in around the diameter of the filter.
When you are running in dusty areas you always want the most effective filter you can get and monitor it closely. I have 3 of the Amsoil round filters in my basement and they re reusable. They are $25 each NIB and can be washed out with soap & water. For the oil youu can use the K&N oil for them. Dave & Sasha
Price has risen $5 each in four posts.
I went with a rebuilt steering column. My first mechanic effed it all up and had to go with another mechanic and had it sent back to be rebuilt AGAIN. So far its good to go.
Speakers? I have two Radio Shack mini speakers in the front and a wooden boom box with marine speakers in the rear. Can't hear 'em. Radio stays off unless we are on a mountain road or parked. That might change with the new to me old top. A muffler might help too.
Air filters are like oil, tires, and beer. Everyone has their own preferences and heaven help us if we try to convince them otherwise.
When we first parked the Jeep in the drive it had a 4" Mr. gasket air filter. That little some beach could clog up in a day's time. Everyone said replace it with an original but couldn't tell me where to find one. Close by we have a hillside graveyard where old jeeps go to die--like the elephants do in Africa. He didn't have one to fit a 258 with a YF. "We can make this one work, but honestly I sell them to folks doing restorations and I price them high." I bought a full-size Mr. Gasket and found that it used the same filter as the OEM. Then I discovered that the K&N I bought for my 87 S10 was the same diameter, but a tad taller than the Jeep filter. That\s what it uses today. During pine pollen season it keeps the pollen out of the carburetor. That chit will turn a black Jeep green overnight. I can't tell if it increases fuel economy because I did several things to it at the same time and the mileage did improve. Power maybe, but it did give the engine a different sound.
The main advantage I see with the K&N is that I can refresh it without waiting for the FLAPS to order a new filter which they never had in stock. Refreshing is part of the spring ritual of changing oil, checking the fluids, lubrication, tire rotation etc. If I didn't already have a K&N filter I probably wouldn't have bought it.
That's my $.02 worth although there ain't much you can buy for $.02 anymore.
Thank you, I'm gonna try one and then another and see what works best. I have a 2007 Dodge R/T magnum and had a K&N cold air intake and loved it. So...K&N might be the go to.
Interestingly enough I’ve used K&N twice on different cars and in both cases it changed my torque and lowered my gas mileage. An ASE certified mechanic told me Those results were not uncommon. BTW what did you end up using for a steering column?
Sorry, I forgot to say, I got the rebuilt steering from another friend on here and went to J&W Jeep. Home they were awesome and very helpful. If you're looking for a steering column and can't find what you need, check them out.
I like in dash 5-1/4" speakers that fit the CJ dash studs and speakers behind the front seats, Vertical Driven product, with some decent made speakers. Nothing too expensive as being exposed means getting ripped off from prying eyes.
That is exactly what I want. Looks fantastic!
FYI
I used speakers from a Jeep YJ factory roll bar speaker pod for the dash speakers. Good sounding and heavy magnet on those suckers. If you can find them now in a junkyard, I recommend them. And grab as much of the wiring harness and speaker plugs too, you'll need the plugs for the speakers as they are Chrysler type.
Gas Audio equipment Composite material Cable Metal
See less See more
K & N type filters are trash if you want long life from your engine. If you can read and understand technical articles, read this:
PS put emphasis on "If you can read and understand technical articles". If you think it doesn't apply to your engine because it has a different brand name, this is over your head.
I'll remember that if I ever put a Duramax in my CJ5. Until then it has little relevance.
Completely relevant. Just because the test engine filter application is a duramax doesn't mean the results won't cross over to any other motor or it's corresponding filter.
Here is a great article.
Pretty much the same one as above only with the charts and graphs visible and a more in depth explanation.
As can bee seen, the K&N ranks at or near the bottom in just about all the tests.
Reactions: 1
FYI
I'm looking for the back wedge speaker boxes, where did you pick those up from. I checked out amazon and it said the ones they have do not fit a '77 CJ7. Thanks for all the help.
I got them from NAPA Online. Might not fit your year roll bar as they are made for late 1979 and newer style roll bars.
Summit Racing has them too: https://www.summitracing.com/parts/...CmcdipDFSG6mMt9TElSUyOuPAj9g_6cMBTe59jbmp5HPA
I'm searching. Thank you!
Jesus
Reactions: 2
Prayer is allowed here!
As for my sound system your comments fall upon deaf ears. That is the least of my priorities. I seldom turn it on. I prefer to listen to a well-tuned and unmuffled 258 when on the road.
I'm also going to keep the K&N!
Bob out.
Reactions: 2
41 - 56 of 56 Posts
