Price | $600 |
Pros | proper angles are restored. The transmissions sits where it originally was and in turn shifts smoother. The tcase no longer leaks. a much smoother ride. |
Cons | none |
Recommended | yes |
Price | $495 |
Pros | Stout, easy to install, TW driveshaft |
Cons | Just having to remove the skidplate to install |
Recommended | yes |
Price | $600 |
Pros | cheap, pretty strong, and easy to install. |
Cons | rusty's gave me the wrong length shaft |
Recommended | yes |
Price | $400 |
Pros | Easy upgrade to make. |
Cons | The rear output seal went after a 1,000 miles. This was due to a rough spot on the yoke. It may have been damaged during shiping however it was easly repaired using sand paper and i have had no issues since then. |
Recommended | yes |
Price | $505 |
Pros | Quality workmanship. |
Cons | Expensive. |
Recommended | yes |
Price | $460 |
Pros | No vibrations! |
Cons | None so far. |
Recommended | yes |
Price | $500 |
Pros | none |
Cons | none |
Recommended | yes |
Price | $1000 |
Pros | Fixes driveline angle problems |
Cons | ??? |
Recommended | yes |
Price | $472.5 |
Pros | Eliminated all driveline vibrations created by the 4" lift. Eliminated the need for the T/C drop and relocation brackets and returned everything back to stock locations. |
Cons | NONE |
Recommended | yes |
Price | $525 |
Pros | great service |
Cons | none |
Recommended | yes |
Price | $450 |
Pros | top quality parts, east install |
Cons | make sure you have correst ds lenght |
Recommended | yes |
Price | $500 |
Pros | Easy to install in your garage, more solid connection from T-case to Diff. |
Cons | none yet |
Recommended | yes |
Price | $600 |
Pros | Great Kit |
Cons | Lack of intructions |
Recommended | yes |
Price | $465 |
Pros | Great quality and price |
Cons | None |
Recommended | yes |
Price | $500 |
Pros | Strong, well built |
Cons | The paint on the driveshaft comes off very easily. |
Recommended | yes |
Price | $480 |
Pros | no vibrations, corrected drive-line angle, easy install |
Cons | the actual shiny part of the shaft rusted badly |
Recommended | yes |
Price | $525 |
Pros | Fit well and install was easier than expected |
Cons | n/a |
Recommended | yes |
Price | $499 |
Pros | No more vibrations. |
Cons | None |
Recommended | yes |
Price | $600 |
Pros | Very strong and looks really good, easy to install |
Cons | none |
Recommended | yes |
