1 - 20 of 64 Posts
Product Information
Price $875
Rating 4
Average Price $497.91
Manufacturer Advanced Adapters/Tom Woods
Recommended Yes: 63 / No: 0
This kit is a Slip Yoke Eliminator from Advanced Adapters and a new Tom Woods Drive Shaft.
Price $530
Rating 5
Recommended yes
Comments: Ordered from Tom Woods, the man himself. One of the most worthwhile mods I have done, and probably the longest lasting...only time will tell.
Price $500
Rating 5
Pros Drive shaft stays in the truck!
Cons No interesting conversations with the state police about why my drive shaft is laying on the ground.
Recommended yes
Comments: works great my drive shaft doesnt fall out and make my truck do its pole vault impression anymore....
That experience cost me 2 leaf springs and a rear.
Price $500
Rating 4
Recommended yes
Comments: The order process was easy and the product shipped the next day. My residual vibrations were reduced to zero and I was able to get rid of the transfer case drop.
Rating 5
Recommended yes
Comments: It's an sye and they are basically all the same. Straight forward install and is holding up well.
Price $499
Rating 5
Pros great fix, fast install, Stronger than before.
Recommended yes
Comments: after I added the lift my drive shaft was withing 1/2" of falling out. This fixed the prob. also helped stop the binding on the drive shaft due to angle. and with the extra travel its set so I can add more lift latter if i need to and this wont need to be changed. So I am very very happy. I will put it on every jeep I own from now on. took about 2 1/2 hours and i didnt have to take the transfer case out so that was a plusssss:2thumbsup:
Price $513
Rating 5
Recommended yes
Comments: Great price even after adding the extended life splines to the cost.(35.00) Easy install, and well made. Fast, fast shipping. NO MORE T/C DROP WOHOO and no vibrations. Also no more shifter problems.
Recon death squad
Rating 5
Recommended yes
Comments: AA SYE kit was actually a breeze to install. Did it in a night with a buddy.
Tom Woods CV shaft is an awesome product. Guaranteed for life no matter what, as are the U-joints.
Price $525
Rating 5
Recommended yes
Comments: I bought this after a U-Joint on my stock driveshaft broke loose, slapped a hole into my muffler, and broke the output shaft of my Tcase.
This kit is great, straight forward install, and good customer service from Tom Woods. 3000 miles later, still smooth.
Price $480
Pros easy installation
Cons didnt recieve instructions with SYE
Recommended yes
Comments: You do not need to remove transfer case for installation. The transfer case on my rig had to have the shifter bar cut back to only allow 1" max protrusion from rear half. I believe this is only necessary to cut on a few NP231 t-cases.
Price $480
Pros very easy to get parts in only if you take the whole tfc out driveshaft from tom woods is great quality
Cons no problems with tfc and tom woods
Recommended yes
Comments: i bought this online from rustysoffroad.com good place for cheap and great quality
Price $500
Pros such a better angle. no more stress problems
Cons yoke is weak. trust me...
Recommended yes
Comments: dont lift your jeep without getting an sye. and dont get anything other then a woody.
Price $445
Pros Does everything a SYE should. Price for what you get.
Cons Takes a while to install and measure for the new shaft (all SYE's are this way though)
Recommended yes
Comments: The best SYE + CVDS combo you can get for the price. It's an easy install, but if you do it right, it's time consuming. Stopped my DS vibes and allowed me to get rid of my t-case drop.
1 - 20 of 64 Posts
