Price | $2260 |
Rating | 5 |
Recommended | yes |
Price | $2421.23 |
Rating | 5 |
Pros | All gear driven goodness, 4.3:1 low range, Independent Axle Control |
Cons | If anything the weight and size |
Recommended | yes |
Price | $1995 |
Rating | 4 |
Recommended | yes |
Rating | 5 |
Recommended | yes |
Price | $1000 |
Rating | 5 |
Recommended | yes |
Price | $2300 |
Rating | 5 |
Recommended | yes |
Price | $3000 |
Pros | Great gear selection, 2 LOW |
Cons | Price |
Recommended | yes |
Price | $2000 |
Pros | HD output front and rear 32 spline, |
Cons | size and retrofit |
Recommended | yes |
Price | $2200 |
Pros | The ability to switch the front and rear diffs in and out of 4x4 |
Cons | none |
Recommended | yes |
Price | $3550 |
Pros | everything |
Cons | nothing |
Recommended | yes |
Price | $3400 |
Pros | Great selection of gear ranges |
Cons | Price |
Recommended | yes |
Price | $2900 |
Rating | 5 |
Pros | love the options of many gear choices at your finger tips. |
Cons | spendy but you get what you pay for |
Recommended | yes |
Price | $2300 |
Pros | Bomb proof. Great quality. Built to my spec's. It's an Atlas! |
Cons | Took a looooong time to receive, but I guess that's to be expected from a build-to-order company that puts so much emphasis on quality. |
Recommended | yes |
Price | $2100 |
Pros | It's an Atlas what's to say ;-) I got it free from the '09 Jeep Safari but the site wouldn't let me put in 0.00 |
Cons | Tight fit with a 33 engineering skid even with a bit of work with the BFH on the tub. Not really a con but the only one I could think of. |
Recommended | yes |
Price | $2000 |
Pros | The Atlas II is super tough, and very reliable. By the way the drive shafts attach, you have the option of disconnecting a drive shaft and still retain mobility should anything go wrong down stream of the t-case. |
Cons | As a shift-on-the-fly t-case you must be moving to shift. This can take some practice in certain terrain. |
Recommended | yes |
Price | $1 |
Pros | 11.7 - 1 |
Cons | none |
Recommended | yes |
Price | $1 |
Pros | , |
Cons | , |
Recommended | yes |
