confusing - you are in the Cherokee XJ forum, under your name it says "1999 FSJ cherokee"
I tested the relay: connected terminals 1 and 2 to the battery and heard the click of the electromagnet engaging. Checked continuity across terminals 3 and 5 on the relay: no resistance when the relay is engaged. I didn't see any similar relays I could test with.the relay is a great place to ck circuits for AC. A test light and we can ck - relay control circuit and comp 12v supply
ANSWER - swap with a similar relay, hopefully horn, wipers, are the same for testing.
Smack it with a hammer! I can get behind that! I thought of that too but the front of the compressor is immediately behind the cowling for the fan blade. Hard to get to safely.Check to see if the compressor is getting 12v. If it is, smack the center of the A/C pulley with the handle end of a hammer if you can safety get to it while the engine is running. See if that makes the clutch engage when you have the A/C turned on and the low pressure switch is bypassed.
Good suggestion but I'll need to find someone I can borrow that from. I am currently unemployed so I need to get this AC situation resolved on the cheap.Do you have a gauge set? If not get one. The static pressure can be as high as 60psi, yet when the compressor engages it can drop below 20psi. That causes the low pressure switch to cut the compressor off. As static pressure builds back up the compressor engages again, cuts off again, etc, and you have no cold air. If the charge is very low the compressor will never come on. The correct procedure is to purge the system completely, vacuum it down with a vacuum pump to get any moisture out, then recharge with the correct amount. If all else is good you should get proper AC. But without doing that you are guessing about everything else. .
As the compressor wears, the clutch may not engage when power is applied. I've seen them where the gap is just a bit too big for the magnet to pull the clutch in. A slight tap makes it pop right in. Just something to check that can throw you for a loop.Smack it with a hammer! I can get behind that! I thought of that too but the front of the compressor is immediately behind the cowling for the fan blade. Hard to get to safely.
Good idea. I have not checked to see if the compressor is getting 12 v. I'll need to dig around a bit to find where I can check that.
I have a multimeter. What's the procedure for checking the relay for 12 volts?Or check for 12v at relay then procede step 1 then 2 and on to 3....
B1 and B5 should have 12v,
B3 is a ground (PCM)
B2 goes to compressor
Need help with that? Just a test lamp is needed and the above diagrams
1999 XJ 4.0L.
