What is a TCM that transfer case mount?For starters, a very short rear driveshaft. Electronics, as in, TCM, wiring etc.
transmission control module, depending on the year XJ, can be external or internal of the PCM (engine control module)What is a TCM that transfer case mount?
What would you think something like this would costtransmission control module
99 TJtransmission control module, depending on the year XJ, can be external or internal of the PCM (engine control module)
What about the transmission and or the rear drive shaftUsed with a good harness ? Couple hundred bucks maybe.
I have 410 gears would it be cheaper to go with a lower gear like 392 or 373I mean the AW4 is probably from an XJ. Used them from 87-01 in those.
Make no mistake, it will be a challenge. Probably a lot of fabrication.
I knew it had been done, the guy that bought my CJ7 years ago said he was doing it on that.Stu Olsen Offroad used to have an excellent write-up of his AW-4 swap. IDK if his website is still around.
You might want to start here >> AW-4 Swap into a 97 TJ
The AW-4 TCM is external on all years of XJ.
