Need some help figuring out what is wrong. I pulled the motor and tranny (4.0&ax15) replaced with crate long block and new trans. Now it acts like timing is way off and if it starts the exhaust header turns cherry red in seconds. Like it is running way too lean or Time advanced. I thought I may have put distributor in wrong or something was wrong with the crate 4.0. Took all down again ran compression test 135 is good. Lined up timing mark TDC installed a new distributor oil pump @11 , roter @5pm and there is no change. Have fuel pressure 38. New TPS. I know start is open system PCM and belive the electronic timing adjustment should be minimum at this point. CPS wires show no resistance on multi meter so should be good? O2 shouldn't read in open or start condition? Can change it but don't think it will make any difference. I sprayed wd 40 on intake while running and didn't detect any vacuum leaks.
Suggestions?
On a side note I did the same to my 94 and it had no problem i am now 7000 miles in and am very happy with it. The wife is not impressed by me tearing hers down and not being able to get going..
Thanks for your thoughts on resolve.
Happy wife happy life ;D
Sent from my SM-G975U using Tapatalk
Suggestions?
