89 YJ EGR Tube after 4.0 head swap
194 Views 2 Replies 2 Participants Last post by  fishadventure
Hi all,
I did the 4.0HO head swap years ago on my 89 YJ 4.2L but recently moved to the Las Vegas area and due to recent law changed I need to pass smog.
For this I need to rig up an EGR Tube. I figure with some fittings I should be able to make something work.
Real question is if anyone knows the thread size of the intake side. I've read it is 7/8-18 but then also someone mentioned a metric size in another post. Just looking for clarification so I can get the right fittings and not have to pull the intake to confirm.
Thanks in advance!
1 - 3 of 3 Posts
To update in case anyone else is in need I was able to do a few tries with different threads and can confirm the EGR tube uses a 7/8-18.
Is anyone wants to block the intake side of the EGR tube (not usually necessary) you can use Dorman 65231 Oil Drain Plug.
  • Helpful
Reactions: 3
We used to use a nickel under the fitting. It looked stock…
1 - 3 of 3 Posts
