1 - 8 of 8 Posts
Just noted the steering knuckles on my 88 are shot. Can't find new ones anywhere, but I noticed the 90-95 steering knuckles are all over. The main difference is the 87-89 knuckle has a separate brake caliper bracket mounted using two bolts to the knuckle where the 90-95 has the caliper bracket as part of the knuckle. Does the 97-89 steering knuckle have any mayor differences besides the brake caliper bracket? Will it work on the 88? Can I use the 87-89 calipers on the 90-95 knuckle? Any help is greatly appreciated.
· Premium Member
I think there are two issues. My 87 has a different caliper hat height off the unit bearing (2.5” VS 2.125”??) and the wheel face portion was much thicker than the later ones. Which is related to the second thing: the caliper is different as well. And takes a slightly different shaped brake line.
I may be wrong on the fourth point which is the early ones had a banjo line of one size/thread but 89? is the same as 90-95? I can’t remember- I just know going from an ‘89 D30 to the 91 front axle I bought new soft lines and had to borrow the used ones off the old axle and bend a little cuz something wasn’t right on the new ones. Metric VS standard? Can’t remember.
Just did front pads/rotors on my ‘87 and it took three trips and two stores to get rotors and pads that were the same as what I took off. Granted the first trip was for ‘94 parts cuz I have a 1994 motor/trans, but either they screwed up or there’s a third size. Gut says the screwed up but I don’t know... 89 parts fit. Amazon sorta has only early and late parts.
If you want to use the later knuckles, then you will need to use the wheel bearing/hub assemblies, brake rotors, calipers, and pads from the later models as well.
Does anyone have a source for these replacement knuckles other than Ebayy? The only way to do the Wilwood brake upgrade kit I already have is on those knuckles. I got the brake kit years ago for a car I no longer have, before the stream of answers of “Why don’t you just…..” come in.
· Premium Member
I would watch CL, FB market place, etc for entire front diffs also. Sometimes guys scrap them or sell them dirt cheap after doing Tons upgrades for instance. You maybe able to get everything that you need on the cheap.
1 - 8 of 8 Posts
