83 CJ7 Finally out of storage
15747 Views 99 Replies 22 Participants Last post by  Rkuehljr
4
I have had this Jeep since 85. Title says I am the original owner but there is a story that Maurice Cheeks bought it for his girlfriend in Texas and put plates from an old VW on it. In 85 he traded it with the same dealer who delivered a Camaro to Texas and drove this Jeep back to Indiana. As I recall, it had like 5,000 miles on it when I bought it. Anyway, it was my daily driver until 92' and got parked in the garage in 1998 with terminal skin cancer.
In July 2019, I finally had the time, motivation, and budget to start the restoration I had alway planned. So I rebuilt the carb, bought a battery, and bungee corded a gas can to the grill with some plastic tubing for fuel lines and fired it up.
Sent from my iPad using Tapatalk
See less See more
61 - 80 of 100 Posts
I was tracing out the manifold heater circuit and I see how it was supposed to work. But then there is this…
Some mechanic has put a jumper across the wires going into the oil pressure switch effectively removing it and triggering on ignition on instead of engine running. Begs the question; do I fix the wiring now while I am in wiring mode and expect to replace the pressure switch once I have it running again and can check it. Or put it back the way it is and come back to it later?
See less See more
I have to admit that was a clever klooge. I guess you can always check to see if the oil pressure switch works by using an ohm meter to see if the contacts close or not when the engine is running. If it works or you intend to replace it, then remove the splice and get some something to protect the wires.
The problem with that type of splicing connector is that it cuts thru the insulation and exposes the wire inside to the elements which could lead to corrosion and the wire corroding away.
There is some type of "liquid electrical tape" for wires you can use to put over the cut if the wiring inside is OK.
https://www.amazon.com/s?k=liquid+e...410077&tag=googhydr-20&ref=pd_sl_2v3ilqw9mm_e
Thanks John, I'll have trace out how that temp sensor fits into that control. It is a single wire device, so it must be a NC ground switch? How does the thread sealant not insulate it?
If the tread sealant was used correctly, A lot of it gets worn away and you will still have good metal to metal contact. The sealant just fills in the open spaces that are left over.
2
I think I finally fished up the wiring cleanup and Sniper ignition install this evening. That took way longer than I think it should have, but I’m pretty satisfied with how it came out. Going to have to wait to see if it works. The spark plug wires I bought for this upgrade were for a stock ignition which doesn’t fit the new ignition. I’ll have to see what I can work out with Magma or.
Motor vehicle Hood Vehicle Automotive design Automotive exterior
Motor vehicle Automotive battery Hood Yellow Car
See less See more
I got the plug wires back after Magnacor replaced the terminals and made me a new coil wire, so I was finally able to try it out. After re-running the Sniper wizard so that it would control the timing I cranked it over and nothing. Not even trying to fire. So I pulled the #1 plug to confirm I had the distributor installed correctly; it was. So I pulled the fuel pump relay and clamped the #1 plug to the alternator with the wire installed to see if it was sparking; it wasn’t. The LED on the module was glowing yellow, so I new it was getting power, but it was clearly not command a spark. So after sleeping on it I could finally bring myself to open up all the wiring and loom I had so diligently tucked away and secured. Nothing seemed to be obviously omis. So I started looking at the connectors to Sniper to be sure I had landed everything correctly. Somehow I had managed to connect the white points output to the yellow coil -, and had not been concerned about no wires being connected to a 10 pin connector. So after moving the points output to the correct place, I was getting a good spark. After reinstalling the spark plug and plugging the fuel pump relay back in it fired right up on the second revolution. I then went to setting the timing per the instructions with the timing locked at 15 deg. At 750, 1500, & 3000 rpm. I need to increase the inductive delay because the timing advanced to about 17 deg at 3,000 rpm, but that will have to wait until I can get it outside. Note to others: a shop vac hose is not suitable to use to vent exhaust outside.
I’ve also picked up a pair of NT axles that have 3.54 gears in them this past weekend. The rear axle tubes are wasted as the u-bolts have worn deeply into the tops of the tube, but the gear sets are what I was really after. They came with 2-1/2” lift springs but they look like they are going to be stiff and may be ProComps. I am probably going to go ahead and install them, so that I can comfortably install 33” tires and replace the 30 year old rubber it is currently sitting on. My budget doesn’t support doing all this now with new parts, so compromises are the name of the game. I have the axles all pretty well broken down and with the exception of to tube damage, they were in amazingly good shape. I now have a pretty good start on extra/spare parts. Anyone have any suggestions on getting rear axle flanges of the shafts? I have damaged 3 pullers so far without any movement. I’d like to salvage the drum brakes and I am just about ready to try cutting the bearings off and trashing the shafts.
Tire Automotive tire Motor vehicle Tread Synthetic rubber
See less See more
2
I quit procrastinating today and did the wet sanding. I plan to do the polishing tomorrow so that task will be complete.
Tire Automotive parking light Car Wheel Motor vehicle
Wheel Tire Car Vehicle Automotive tire
See less See more
Reactions: 3
“Anyone have any suggestions on getting rear axle flanges of the shafts? I have damaged 3 pullers so far without any movement. I’d like to salvage the drum brakes and I am just about ready to try cutting the bearings off and trashing the shafts.”
I'm not sure what you are saying. I understand you bought some NT axles, and want to use the 354 gears, but that’s where it ends.
Are you have troubles disassembling the NT axle?
Ax, I did have trouble getting the flanges off. I figure I’m going to do something with the drum brakes. I ended up buying a proper hub puller and with a BFH was able to get them off. I still need to put one piece axles in mine, so I figure I can use the puller for that. At least that is how I justified buying myself another tool.😁
2
I was able to finish the wet sanding and polishing today. It’s no show paint job, but I’m OK with it. Found a few spots on the body where I should have blocked the primer and an area the color is a bit thin, but then I just spent 10 hours going over it closely.
Tire Wheel Hood Vehicle Automotive tire
Hood Tread Automotive tire Wood Bumper
See less See more
Reactions: 2
2
I’ve been making steady progress over the past several weeks, I just haven’t actually finished much. One of those projects has been a replacement glove box for the water damaged and distorted original fiberboard box. I had a guy from work use the original as a template and folded me a new box out of sheet metal.
Motor vehicle Automotive lighting Yellow Hood Automotive design
I have had this idea that it would be more useful with a shelf to separate the document storage from the general use clutter. I also thought a USB port inside could be useful.
Gadget Audio equipment Gas Technology Electronic instrument
After painting the interior black I figured some LED lights would be cool.
By the way, I have the paper label for the tire size & inflation that is missing from the door. Does anyone know what I should use to re-adhere it?
See less See more
  • Love
Reactions: 3
You and your coworker should market that glovebox.
Reactions: 1
2
If this doesn’t work I’m going back to drum brakes. A couple years before I quit driving this Jeep I put disk brakes on the rear for SSBC. The brakes themselves worked fine, but I couldn’t figure out how to connect the parking brake cable to make it work. I have had the bracket on every bolt available but couldn’t get the pull angle correct for it to generate any real grip.
Automotive tire Motor vehicle Bicycle part Wood Vehicle
In a final attempt I welded the bracket directly to the axle tube so that the pull be over a tight angle. I got it adjusted and it seems like it is going to work.
Automotive tire Automotive design Motor vehicle Bumper Auto mechanic
See less See more
I think he would like to, but I don’t want to do the mods and painting. I am far too slow.
I can finally call this little project complete. I have been racking my brain trying to remember where I put the plastic thumb nut and rubber cushion for safe keeping. They finally turned up today when clearing off the table saw so I could cut some aluminum.
See less See more
4
I’ve been waiting for weeks to get the last 2 plastic push retainers so I could install the trim panels. The wife pointed out last night I still had about 10 of the originals. So I just finished that up. The decals went on a while back which really moves it toward looking complete.
Tire Wheel Car Vehicle Motor vehicle
Tire Wheel Automotive parking light Vehicle registration plate Automotive lighting
Tire Wheel Vehicle Motor vehicle Hood
See less See more
Reactions: 4
Great Job!
2 weeks ago I noticed some condensation on the inside of the windshield while I was driving home. After changing clothes and coming out to work on the Jeep I noticed a puddle of a new fluid forming underneath. Most of you already know that the heater core has started to leak. So dash back out so I could take it to a local radiator shop so that they could re-core it. 2 days and $120 later I’m back in business. I guess I could have ordered a new core for less, but never even considered it because they are all aluminum. So with the dash laying on the seats, that was the opportunity to put LED bulbs in the gages, replace a broken bulb holder, land rear speaker wires on the amp, and install the glovebox. Re-installing the dash and checking out the LEDs, I start smelling something warm which is never good around wiring. Turned out to be the original headlight switch dimmer was literally falling apart, so a simple replacement to fix.
Oh the joys of working on an old vehicle… seems every time one fix one thing, two more rear their head. I still have to sort out what I did to the oil pressure gage. Before the heater core, it was working fine; now it shows 60 psi without the engine running and pegs when it is running. I guessing I connected it wrong, but the amp is mounted in the way of getting my hand up there, let alone seeing.
See less See more
Oil pressure gage problem solved. I had the black & purple wires reversed. Goes to show the value of really good disassembly pictures.
Reactions: 2
I was going through a box of stuff my wife drug out and found this gem. Now I know for sure how it was originally equipped. Didn’t release it left the factory with no top, I had always thought is was originally a soft top.
Font Paper Paper product Document
See less See more
Reactions: 1
Thats pretty cool! nice find!
Hoss
