Maybe this will be a quickie. My 1978 CJ7 has been over charging. Like most everything today - parts come from China. When I start up, the ammeter gauge reads just over 12 volts. When I rev the engine to about 1400 RPM, the gauge jumps to near 16 volts. With everything running (lights, heater blower on High, turn signals on, brake pedal pushed, wipers on) the voltage drops to about 14-15 volts.
The battery is a quality battery and only about a year old. When the voltage reads reads high - the head light beams are REALLY bright. I'm certain I'm not getting a false reading from the ammeter. Once I have revved the engine and get that high voltage reading - it stays high - even when I let the engine back down to idle speed.
I replaced the alternator twice with rebuilds from O'Rielly Auto Parts but still the same issue. I've never changed an internal voltage regulator in an alternator, but that looks like maybe my next move.Again with parts today, I just resolved an oil pressure reading after changing out 3 different new oil sending units. I hope not to go thru the same thing with voltage regulator issue.
If it IS the voltage regulator (and if this sounds to you like the issue) - can anyone recommend a GOOD voltage regulator or a source for a dependable replacement? 16 volts seems pretty high.
