Seems quite a few folks are having fuel pump issues lately.
Your original pump may be "tired" and finally failed--they all do eventually.
Where did you get your new pump from?
There might be some kind of diaphragm issue from cheaper or foreign made pumps.
In other recent threads, other folks have gone to a different store to try a different brand.
I'm pretty sure a lot of them have had good luck with NAPA auto parts fuel pumps.
Standby, you'll get the scoop soon from another!
I've had mine a long time and bought a spare that I keep in my Jeep.(Both were purchased at
Advance Auto Parts with a lifetime warranty). This being before the recent problems happened.
Even though mine are the "inexpensive" types, they have lasted for years.
Maybe the issue will finally get fixed and even the cheaper pumps will work right.
Try a different store at minimum.
As far as the volcano carburetor, your issue sounds like the float was stuck down, not letting the
needle and seat to close when the fuel in the bowl was at it's proper height.
Really high fuel pressure can also "over power" the float, I can't see a mechanical pump doing this,
I could be wrong!
-----JEEPFELLER
I could be wrong!
-----JEEPFELLER
