So the other day I got my engine pretty hot, it reached the last solid white line before the red zone so about 240 degrees, i wasnt towing or anything just got hot in 109 degree weather in traffic. I drove it around some until it got back down to 210, let it idle a bit there then shut it off to avoid heat soak. When i went to drive it again i was having issues with it going into 4th gear.
The problem only lasts for about 5 minutes of driving and it basically stays in 3rd gear even if I’m driving 50+mph. I’ve gotten pretty good at telling when the transmission should shift at different speeds, usually it shifts into 4th just over 30mph. After it shifts into 4th after 5 minutes or so it shifts completely normal for the rest of the time it is running and even goes into overdrive.
There seems to be no correlation to when it decides to shift normal other than time, even if i try manually shifting or putting it in neutral.
It also doesnt matter if i shut the car off for 1 minute or 1 hour it seems to “reset the clock” after every time I start it.
I dont believe it is a mechanical problem becasue after 5 mins or so it acts completely normal, so it leads me to believe it is electrical I just dont kno where to look. I also want to solve it now before it may become a permanent problem.
So what do y’all think could be causing this? It has been in the 100+ in Texas recently and I’m wondering if its maybe a cooling feature or something i dont know. Any help would be great let me know if there’s anything i can easily check soon.
