It uses no oil at all, when I change it at 4000 the level is exactly where it was when changed last time. No smoke, nothing. I have a catch can and a modified PCV system derived from the later ones, usually about a tablespoon of oil every thousand miles. That cylinder is the only one with crud on the valves, notice number 2 in the background has cleaner valves. Not only were they not staked I was also told the seats were replaced with real steel ones, that didn't happen either. My local machinist gave me a steel seat, Stellite, and attempting to mar the surface is impossible with my crappy wire cutters yet they will put a noticeable dent in the seat part that broke off. He looked at it for a second and knew it came from a Chrysler, does a lot of them on early Hemis that have the same issue. I believe I was jipped on the valve stem seals as well, probably used as cheap as possible. And now that the new head is on the hits just keep coming, this is what happened on initial start last night..
