1 - 7 of 7 Posts
About four years ago I swapped a 1998 4.0 with an OBD 1 computer into my 1981 Wagoneer. It's been running fine and without issues. Recently I swapped the battery out and now the engine will not start. The starter will engage and crank the engine.
I have checked and can verify that the fuel pump is no longer priming when the key is on. It is also not running while cranking. I have jumped the relay with the power distribution center and the fuel pump will run - so all of the wiring from there is good. Thinking that I just the problem popped up when I changed batteries, I ran new battery cables between the Starter and PDC as well as a new ground, but the problem is still there.
I have not checked for spark yet (as not having fuel seems to be at least one problem). What would cause this to occur? Is it likely that my ECU died?
confusing -
are running a 1998 PCM?
1998 is OBDII - so IDK what we have.
the relay is installed in a 1998 PDC (underhood fuse box) OR something else -
YOU jumped relay was thhere 12v to relay load side?
The Jeep is becoming a frankenstein of parts from other cars / years... I really should put it all in a spreadsheet someday.
The engine is a 1998 block (I believe from an XJ). The ECU / Wiring harness is from a 1992 XJ (OBD 1). The fuel pump relay is installed in the under hood PDC that is part of the harness. To verify that the fuel pump is working, I supplied 12v to the load side of the fuel pump relay and the pump runs without issue.
All that to say, when I turn the ignition to On, the fuel pump no longer primes (or runs), but I know the issue is not (1) the pump itself or (2) the wiring after the PDC.
then the control side of relay - and we have a PDC from the 1992 XJ -
I don't have quick access to that old a diagram BUT will try, in mean time
there should be 2 fuses for FP the load side you say is good the contro side has a fuse also - give me some time
NOTE - Are you aware the fuel pump will only get 12v for 3seconds if jeep is not running, makes troubleshooting tricky - 2nd person is helpful
Discussion Starter · #7 ·
A little injury took me away from this for a while, but I wanted to share an update for future readers.
I traced all the wires in the diagram above and confirmed that everything was working as it should when power was applied to the correct wires. Eventually I traced the wires back to the ECU, and ensured that there were no breaks or shorts in any wires. This led me to replace the ECU which solved the problem.
1 - 7 of 7 Posts
