I have a 2000 XJ with a 3" lift. Should it have spacers to drop the transfer case down to adjust the drive shaft angle? If so what is the thickness of the spacers? I get some vibration when I decel I'm wondering if this could be the cause.
Lift kit vibes are excessive wear on the t-case bearings. 2000-01 are more prove to drive line vibes than earlier models years. A t-case drop may reduce the vibes, but it also increases the front drive-line angles, and the strain on the motor mounts. An SYE is the solution.
I put a 3 inch rough country lift kit on my 95 XJ Ran it like that for years. No issues ever came of it. Just make sure your rear driveshaft is in good shape as in greased up and balanced.
I had an interceptor XJ with the 120 mph speedometer. It would do all of that on 285/70/17s and a 4" lift and a 4.0 motor. I guess you need to check all the stuff that goes round and round.
No transfer spacers on that rig either, just my bastard pack homemade lift kit and free shocks from a 4x4 junk pile. All free lift. I built the add a leafsout of Tacoma spring parts.. I only bought the rear hangers for $40.
