Until I got rid of my 2007, I kept oil with me. I would put half a quart of oil in it every time I would fill up with gas. I would also check the oil level a lot more frequently than that. I thought about pulling the timing cover off, cleaning it thoroughl]y, then maybe slather on a bunch of JB Weld onto the entire outside of the cover. I don’t know if that would have worked or helped though.
It is also worth looking for dried antifreeze on the intake manifold. Mine had that but I ended up replacing both the water pump and thermostat housing and tat took care of it. I noticed the thermostats housing was leaking or cracked when the water pump went out. I was relieved that is where the dried antifreeze was coming from.
A lot of the Jeep, particularly the chassis/undercarriage was put together with mismatched fasteners. I forgot if it was metric fasteners in standard holes or the other way around. I had suspected this and then later on I noticed fastener kits started showing up on vendors websites for this very issue. Yeah, Jeep ****ed up that bad.
‘My 2007 would not overheat, but for some reason when I would park, it would heat up my garage so muc, that I started leaving my garage door open for a couple of hours after I would park to give things time to cool down. My 2014 does not do that. My 1981 Corvette does not do tha. My 1995 Harley does not do that.
‘’I had a lot of random computer problems that would cause stuff to sometimes stop working then suddenly start working. An example would be windows would sometimes not go back up or blower motor for a/c not work then later would work fine. Sometimes programmed behavior would change such as horn beep when I would lock the doors. Then sometimes it would suddenly change to no horn beep when locking the doors. I once got out of it and left it running to get an inforation sheet about a house for sale. It was winter. When I closed the door after I got out, it suddenly licked the doors by itself. I had to walk home five miles to obtain my spare keys while the Jeep stayed on the side of the road running. Sometimes the engine would die in the middle of rush hour traffic and not start. I would push it off the side of the road, call a tow truck, and when I would get it to the dealer it would start back up perfectly fine. I didn’t know what was causing all this until later I started seeing stuff about failing TIPM failur. There was some speculation that under hood heat may ge a cause or contributing factor.
I had already gotten rid of by that point.
‘The brake master cylinder was another part that failed early. I think there was something else involving the brakes having to do with a compute. I remember having to drive into and out of a ditch a few times at full speed to avoid hitting the vehicle in front of me because I could not stop or even slow down. I started carrying extra underwear in the glove compartment.
So these are the kinds of things you need to look for.
Is your project an automatic or manual transmission?
