A cool trick is this TFI ignition upgrade that I found sometime around mid-Sep 2002. It involved swapping the stock AMC stuff for a Ford Super Coil, an adapter for the distributor cap, distributor cap & rotor, plug wires, and re-gapping the plugs to a more open setting. The website I first saw this on mentioned .045" as the good setting. I've learned by virtue of stumbling onto a comment in the 4WD Hardware catalog way back then, that there's a kit available to do the very same thing I did, using the same components, and they're running their plugs at .065"!!
Sourcing the parts through a local parts store is a cheaper way to go, and you'll always know where to find replacement parts when the time comes.
After the initial lukewarm performance gain at .045", I regapped mine out to .060" and it's running much better now and pretty much corrected the 'rich' condition from the factory Carter 1bbl that always seemed to be needing a rebuild. The toughest part of the mod was making a mounting bracket for the TFI coil - but I'm sure one could be procured from any '80s-'90s Ford truck with an I-6.
I highly recommend this simple upgrade to anyone with a 6-cylinder looking to squeeze a couple more ponies out of the engine without having to blow all your locker money. My buddy Jim and I also performed a similar mod on his '75 CJ-5 with a 304, using the V8 equivalent distributor adapter cap & rotor, of course.
A couple of pics - the old AMC factory stuff (smaller cap, Permatex'd wires) and the upgraded stuff is newer, of course. Sorry for the messy engine, it's since been cleaned up drastically.
Part Numbers of things you will need (pick your favorite brand - you won't need one of each
Cap Adapter: Borg Warner C193A; NAPA FA139; Wells F960; Niehoff FF78A; GP Sorensen FR109
Cap: Borg Warner C193; NAPA FA136; Wells F952; Niehoff FF78; GP Sorensen FR121
Rotor: Borg Warner D219; NAPA FA159; Wells F953; Niehoff FF59A; GP Sorensen FR106
Ignition Coil: Borg Warner E92/E92P; NAPA IC24; Niehoff FF-179; GP Sorensen GC407S
Coil Connector: NAPA ICC1 (a couple of blade connectors to go between the AMC plug and the Ford Super Coil - I didn't use one, made my own: white wires with blue plugs)
