Before Pictures:
I have heard that, and seen it as well. I have also heard that if the rubber bumpers for the tire are not touching it, it can be go wrong pretty quick. Anyone have a 33x12.5 on a stock carrier with the bumpers spaced out and no problems?id recomend not running it on stock carrier, overtime it will warp and bend the tail gate
I mounted my MV50 to the empty ABS tray. I ran 1/4" air line to to the bumper and to the air box. The intake for the compressor get the same clean air the engine gets this way. I ran the line down to the bumper right above the shock tower down the frame and put a hole in the bumper. Wired a switch inside the Jeep and made a 4 tire setup to air up all 4 at the same time and equalize them. Here are some pictures. If you have any questions let me know. Sorry for the delayed reply.Hey I am interested in how you routed your air line to your bumper, I am looking at the MF-1050 and wondering if you have a write up or info on it?
The 4" OME springs are not the soft 180 or 190 spring rates found on the OME 2.5 kits. I think these are something like 235. I have the numbers for a lot of companies saved somewhere. The long travel OME shocks are matched pretty well to it but it is still a stiff ride. The stiffer but smoother feel that I was told I would have is really true. Takes the big bumps a lot better but lets you know about every single small bump due to the stiff ride.I really like that setup for the air compressor, ill probably do a version of that, Jeep looks great also, how does the lift ride? Also I like the old school Jeep symbol on the grill, really cool. keep it up.
