Hey guys,
I've ran into a little trouble on my 2014 wrangler. I bought it used with 3200 miles on it in February. It is a soft top, but it apparently was a hard top from the factory (has a defroster wiring harness in the back). Here's the troubles that I've been experiencing:
Often - the light on the right most knob (chooses the vents) flashing for 10 seconds up to 3 minutes when the jeep is turned on. When it's flashing, there is no activity from the HVAC unit. Hitting buttons & turning knobs makes no impact on this. It'll just start working whenever she pleases.
Rarely - this has only happened a few times and is much more rare. The air isn't diverted properly. For example, the air can be stuck on the face vents when you're wanting defrost or feet. Nothing seems to make an impact on this. It has just cleared itself up within a few minutes the few times that this has happened.
Soooo... my dealership says that the HVAC system is "searching" for the defroster and is causing all of this trouble. They're claiming that Chrysler says there isn't a work around to turn this searching mechanism off and that I'm SOL. I'm thinking this is totally unrelated. Wouldn't the PCM be the same between a hard/soft top from the factory and just accommodate an additional wiring harness? It doesn't make sense that Jeep would have 2 separate electronic modules when wranglers used to come with both tops as an option from the factory.
Just trying to get some info as to if anyone's had this trouble before - maybe what was done to correct it? Also, if anyone swaps between a hard and a soft top, do you ever have this problem?
Edit: Forgot to mention - this just started happening within the last month or so. I had 6 months of a/c issue free jeepin!
