Hello all. I’ve been experiencing issues with my 2011 Wranglers dome lights, window push button back lights, gear shifter back lighting, door locks back lighting and dome lights not working with the turn signal stalk. The dimmer works only on the dash and climate control back lighting, radio and nothing else. The “door open” on the dash works fine. And manually turning the dome lights on works also. Can’t seem to see any confirmed fix in any of the hours of reading on multiple threads. I’ve checked fuses and possible wire connections issues and haven’t been able to find a fix. Has anyone experienced the same problems? Is it possible the turn signal stalk is defective and the main cause?
