Year:2006
Make:Jeep
Model:Wrangler Unlimited
Mileage:96700 M
Transmission:Manual
Engine:4.0
Trim:Rubicon
2006 Unlimited Rubicon
Needs a little TLC, but otherwise in great shape. Purchased in 2010. In 2014, my daughter was born and I knew I wouldn't have much time to off-road, so I removed the Poison Spyder armor to inspect the paint and clean everything up. Here we approaching 2023 and I have made about 5% progress on the project and do not see I will make more anytime soon so the time has come to clear out my garage. Frame just starting to show some surface rust in some places. Interior tub bedlined with Raptor. Driver side floor pan needs a small repair, had to cut open just infront of the seat bracket to access and removed a broken body mount bolt when I replaced all the body mounts.
DieHard AGM Battery, brand new
New Alternator and Belt
New Aluminum Radiator
Front D44 has G2 4.88 gears and stock locker
Rear D44 has G2 4.88 gears and a front locker installed replacing the LSD
Independent locker switch mod
6" Full traction Long Arm Lift
JCR Front and rear bumpers
JCR Roll Cage
JCR one ton OTK steering
Poison Spyder Rocker Knockers and Corner Crusher armor (currently removed, sandblasted, POR 15 paint and Primer.
AEV Highline Hood and Fenders (Rust just starting at fender seams, driver side rear flare has a crack)
Warn 9.5 Ti winch with synthetic rope
AntiRock sway bar
Tom Wood front drive shaft
Black Magic Brakes
Ten Factory Rear chromoly shafts
Chromoly front shafts
Currently on 35" BFG AT tires
Factory Softtop
Factory Hard Top
Includes Besttop Bikini Top, wind Jammer, and Tonneau cover
More pictures to come
