Year:2004
Make:Jeep
Model:Grand Cherokee
Mileage:203000 M
Transmission:Automatic
Engine:4.0
Trim:Laredo
1 owner vehicle! This was purchased NEW by my mom! I drive this everyday on the road.
Iron Rock offroad 3" lift. Long arm suspension with other mild offroad modifications. You're ready for some serious offroading! Long arm suspension also gives a way smoother ride on road compared to other Jeeps.
The Good
Just passed emissions NV242 transfer case. No major rust! Was garaged all of its life. Was serviced by Schaumburg Jeep its entire life. I have a giant book of service records. A/C works and the heat works!! This is a solid daily driver for me in the winter time.
NO ACCIDENTS!
Recent maintenance
-newer Goodyear Duratracs metric sized 32" tall
-New Mopar TPS
-Transmission fluid changed
-Transfer case fluid changed
-New Bosch Iridium plugs
-NTK coil boots
-New Mopar starter installed about 1 year ago
-Double cardigan front shaft Added on parts
-IRO long arms
-Iron rock offroad 3" lift
-JK wheels
-Iron rock offroad front yoke (to work with the Double cardigan shaft)
-HK Offroad hidden winch plate (with shackle tabs)
-Weathertec floor mats in the front
-Aftermarket projector headlights
-Factory Mopar hitch. Installed with OEM trim panel!
-Transmission pan with DRAIN BOLT (oem pans do not have this!)
-New Pioneer bluetooth radio with built in smartphone holder
The bad
-CEL for O2 sensor
-No carpet. I removed it and planned to go with vinyl flooring but never ordered it.
Extras
I have a box of parts I have been meaning to install but havent had the time. This includes-
-New Mopar crank sensor (I planned to replace it the 2nd time but no need yet)
-Original OEM WJ headlights
-New water pump
-new upper radiator hose
-new lower radiator hose
-new serp belt
-new heater core hoses
-new valve cover gasket
-new cabin air filter
-new wiper blades
