Quite the low mileage find.
I’m at 308,000 miles. Original engine.
I did have to do the headgaskets at about 250k, so I had the heads done professionally and did the timing and oil pump myself.
These engines aren’t nearly as fragile as people claim. Literally any aluminum head can drop a steel seat. The 5.7’s can do it, Chevy LS engines can do it. ANY engine can do it.
My machinist said there's nothing wrong with the engine to half a million miles if you can swap out the intake seats for ones with proper (ever so slightly tighter) tolerances and don't overheat it.
Did your head gaskets melt from the inside out like mine did? Nobody ever changed the coolant and it gets acidic over time. Used to see it on GM intake manifolds a lot in the late 00s.
Mine had the OEM 23 year old water pump when I pulled it apart (and a brand new radiator, and the wrong coolant).
What happens is people don't do it, and then ***** about the engine being made of glass because they broke in some horrifical way at 160Kish.
If you are mindful and do all the PM's they potentially go a lot longer. But, it's a big job and unless you were around a lot of Mercs it seems insane to take an engine apart like that for maintenance. It's not but it seem like it is.
