150000 miles. No drivability issues last two years. Now has random and intermittent ignition failure while driving.Sometimes only momentary, sometimes complete stall. No ignition for 5-10 minutes. Then hit the key and drive home. No codes on OBDII scanner. Have done two hard resets of ECM following Clymer manual. Have replaced ignition switch. Can drive 100 miles with no issue; the next trip will have 1-2 second ignition failure or complete stall. Always starts again after 5-10 minute delay. Dealerships want to throw parts at the problem. I have considered replacing the crank position sensor {170.00 OEM or 39.00 NAPA?} Local shops say abad sensor should throw a code. Key word SHOULD! Any ideas, guys?
