2002 Bella Blue, WJ Build
52591 Views 269 Replies 36 Participants Last post by  snobrdrkid07
2
It seems like build threads are a thing here, so here's mine. Meet Bella.
>>Factory Build Info
Table of Contents:
BUILD
Suspension
  1. 2.5" Lift: OME HD Springs & Bilstein 5100 Shocks
  2. Addco 684 Rear Sway Bar
  3. Factory 2004 WJ 30mm Solid Front Sway Bar (no pics)
  4. Core 4x4 Adjustable CAs (stock length)
  5. Ironman 4x4 UCA
  6. Kevin's Offroad Track Bar Bushings
  7. Rubicon Express Front Swaybar Disconnects
Electrical
  1. Stereo Upgrade 2006: Fosgate Power & Infinity Perfect
  2. Stereo Upgrade 2020: DDIN Kenwood and Backup Camera
  3. Dual Battery and Trailer Charging Port
  4. 2awg Battery and Ground Cable Upgrade
  5. Auxiliary Lighting
  6. Mechman Alternator and 0awg Cable Upgrade
Other & Extras
  1. EBC Brakes (good!) & Synergy Spacers (removed)
  2. Whip Flags: Firestik mounts, Tusk holders
  3. 3M Undercoating
  4. Wolf Vinyl Decal (fight me!)
REPAIR
Suspension
  1. Rear Upper Control Arm
  2. Rear Lower Control Arm (video)
  3. Front Control Arm Replacement
  4. Ball Joint Replacement
  5. Detroit Axle Control Arm Review
Engine
  1. Fuel Injector Connectors
  2. Left Valve Cover Gasket
  3. Right Valve Cover Gasket
  4. Water Pump Replacement
  5. Valve Stem Seals & Lifters
  6. Spark Plug Replacement (video)
Other Stuff
  1. Driver Door Wire Repair
  2. Rear Axle Bearing Replacement
  3. Headliner Repair? -- FAIL
  4. Hood Emblem Replacement
I have had her since July 2002, new to me and the only new vehicle I have ever owned.
Aside from the typical routine maintenance (fluids, filters, tires, shocks, brakes, ...), some of the things I have had to fix over the years. Note: at first I had all of my service done at the dealer or quick lube shops, but after a few bad things happened I started doing it all myself. Well mostly myself. Some jobs I still take to a shop if I feel like it's over my head or I just want somebody else to do it instead.
  • Rear axle "failure" and rebuild at 30k. Dealer stated the diff was empty. Odd, since they did all the service for me.
  • Rear axle "failure" and rebuild at 65k. AGAIN!!
  • Right rear TPM sensor replacement. Jiffy Lube smashed the valve stem for me.
  • Passenger side wiper arm replacement. Jiffy Lube strikes again.
  • Power steering hose, I think this was a factory recall?
  • Evap cannister hose leak. Was throwing a trouble code.
  • O2 sensor replacement. Threw a code so I was going to replace them all until I saw how expensive they are, so just did the one.
  • Climate control panel replacement. The A/C would not blow cold air and really had me stumped. Replaced the panel out of desperation and it worked.
  • EVIC overhead module replacement. Display just died. Got one without TPMS capability because I was running BFG E range tires that would constantly trigger high pressure alarms on the highway.
  • Parking brake cable replacement, TWICE. What is this about?
  • Window regulators on front driver & passenger doors
  • Hood, liftgate, & liftglass struts several times
  • Driver door panel replacement due to cracks in the arm rest. Done this twice too and need to do it again.
  • Passenger side power mirror, I suspect a parking lot incident.
  • Thermostat leak, replaced
  • Water pump leak, replaced
  • Radiator leak, replaced (& hoses)
  • Starter motor replacement, solenoid was dying and threatened to strand me.
  • Engine rear main seal replacement
  • Rear axle seals, bearings, pinion seal
Current list of things that need to be fixed:
  • Peeling headliner (failed 09/05/2020)
  • Driver door panel (arm rest)
  • Driver heated seat
  • Heated seat switches, some lights don't work (but the switch does!)
  • Clunks and creaks in the rear end (completed 11/01/2019)
  • Oil seep from valve covers (completed 03/26/2018)
Obviously I am in no hurry to fix these things ...
Here we are exploring the Lost Coast some years ago. We found a remote deserted beach with a fire ring and stopped for lunch.
Follow along with my adventures with Bella on my dedicated thread:
Gman's Adventures with Bella Blue
See less See more
Reactions: 5
121 - 140 of 270 Posts
Excellent work as usual!! I am considering your idea about the blind side cameras but for a different situation. I sometimes run on narrow trails here in Arizona and this would be an excellent aid in those times when I have to get real close to the edge of a cliff.
Yikes:fear:
Just thinking about getting that close to the edge of a cliff gives me the willies. But if what you are looking for is a view of the wheels and where they are on the trail, I would probably go with an adjustable, "bullet" type of camera so you can point it right where you want it. Something like the Crux CUB-15 that I put on the back of my travel trailer: https://www.crutchfield.com/p_249CUB15/Crux-CUB-15.html
It's got good range of motion. The one I received had enough resistance in the adjustment to hold position but have not road tested it yet.
13
2002 WJ Battery Cable Replacement
Decided it was time to replace the battery cables as part of the dual battery mod. Discovered that my factory cables were still in very good condition. The battery terminals were showing lots of wear though, especially the negative terminal which has been removed numerous times due to past service.
Factory cables are 6awg, this mod upgraded them to 2awg which will be enough to handle a high capacity alternator should that be needed in the future. (Edit: it was not ... I needed to upgrade to 0awg for the Mechman 240A. whoops). The whole procedure sounds easy enough, but I did not really know what I would find when I started pulling the wiring harness apart, so this was also a learning experience for me. There are probably others out there that are curious as well, so I'm writing it up here.
I purchased a new set of cables from JeepCables.com. Most of them were too long. I considered shortening the cables and installing new ring lugs, but in the end I just stuffed most of the excess cable behind the headlight; not a great solution but it worked.
Power Wires (red)
There are three main power wires that I replaced. The first runs from the alternator runs directly to the PDC and has a fusible link (green) at the PDC connection. The second runs from the PDC to the battery (+) terminal. The third runs from the battery (+) to the starter. Note that I also have a blue power cable that runs from battery (+) to the back of the vehicle where I have a secondary battery.
Ground Wires (black)
The cable package I purchased included three main ground wires. The first runs from the fender next to the PDC to the battery (-) terminal. The second runs from the right side of the engine block to the battery (-). The third runs from the firewall to the cylinder head, but I could not identify which wire the supplier meant for me to replace. I think it might be the G100 ground strap, but not sure.
Step 1) Remove the battery.
The tray needs to come out too.
Step 2) Dissect the wiring harness.
I have always wondered exactly what is in that bundle of wires. It turns out, it's not too mysterious. Two ground wires (black), two power wires (red), one starter solenoid wire (light green), two alternator field coil wires (dark green, white/blue). That's it, that's all we have to worry about.
Removing the loom on the bundle that runs to the PDC reveals where the starter solenoid wire and alternator field coil wires come from, and exposes the fusible link on the alternator power wire.
The wire bundle next to the battery is wrapped with a plastic sleeve. I reused this sleeve as an extra layer of protection when I reassembled the bundle.
Step 3) Starter Cable
Following the power wires, we can see the alternator wires head off to their destination while the starter wires pair off to theirs. The starter bundle has a clamp on it that is mounted to the cylinder head with a 17mm nut. Unmount the bundle. Removed the clamp for re-use on the new bundle.
Removed the wires from the starter. With a little encouragement, the starter bundle was free to slide right out the top. A broken plastic wire tie fell on the ground at this point ... it must have been holding the wire loom at one time, but do not really know where it came from. Remove the loom from the existing bundle to pull out the starter solenoid wire because we are going to need that.
Put a little bend in the replacement lug to match the factory terminal.
Bundled the new cable with the existing solenoid wire using a fresh 1/2-inch plastic loom and wrapped it with non-adhesive vinyl tape. Anchored the ends with adhesive wire loom fabric tape to ensure the wrap stays put. Ran it back down where it came from and hooked it back up to the starter.
Step 4) PDC Cables
Three issues to deal with here. The first is that I needed room for the two ring lugs on the new cables and they did not fit in the existing location. So I got a pair of side cutters and nipped out some plastic from the PDC until there was enough room. Had to bend the lugs to make them fit.
The second is that the fusible link was eliminated in the new cable set; instead, we have an ANL fuse holder. The ANL fuse means that the system can be more easily serviced in the field if needed, but the downside is that we need to find room for it. I have an Optima battery with a footprint that is smaller than factory, so I let it sit on the battery tray.
The third issue is that the cables were all too long. I stuffed the excess behind the headlight rather than shorten and re-terminate the cables. This left a fairly ugly mess, you can see the result.
Step 5) Alternator Cable
Not much to say here, really. Removed the old wire loom and alternator cable. New loom around the new cable and existing field coil wires. Wrapped the loom with the vinyl tape and anchored the ends with adhesive fabric tape.
Step 6) Ground Cable G103
G103 is on the right side of the engine block. The cable runs through the engine mount and up to the battery (-) terminal. Needed to put a small bend in the lug to ensure clearance between the wire loom and the engine block, it can get hot enough to melt plastic down here. There is nothing else to worry about here, really. New loom, new wrap for this cable too.
Step 7) Ground Cable G101
G101 is on the fender next to the PDC. This one would have been a slam dunk if it were not too long. Loom and wrap the cable, route it into position.
Step 8) Bundle It Up
Loomed and wrapped all the cables. After several attempts experimenting with routing locations, I basically ended up with the original routing. To reassemble the bundles, I used zip ties to dry fit it until I got it how I wanted it.
Final wrap with adhesive fabric tape added the (probably unnecessary) plastic sleeve removed from the original bundle.
New "military" style terminals, I really dig these.
So that is that. I am left with this cable ... I contacted the supplier through email, strangely enough he could not tell me exactly where to put that cable. I think it must be the G100 ground cable, what else could it be?
See less See more
  • Haha
Reactions: 1
Impressive setup! Where did you get the baby squirrel cage fans?
See less See more
Wow, that is a good question. It was a long time ago when I put the rack together and I was buying most of my stuff from Crutchfield and Ebay at the time. I remember it is a Stinger fan ... probably very much like this one: https://www.ebay.com/itm/STINGER-PR...366798&hash=item2aca95645a:g:pBQAAOSwIYdcwXZA
I do not remember paying $45 for it, but I was kind of going off when I built that rack so maybe I did. All of the pieces on that rack were rather high end at the time ...
Good to know - I've never seen one quite like that, and is actually one of the main reasons my amps continue to take up space in the cargo hold. Thanks for the info!
Interesting information regarding the new cables. Replacing mine has been on my mind for a little while now. Maybe I will avoid this particular brand.
Your works is so well thought out and executed. It's nice to see such care going into these vehicles!
2
Anybody happen to know the size of the nut that secures the G100 ground? I misplaced mine, sucks getting old and senile ... (Edit: Found it! Lucky me.)
Follow-up on power cable replacement (see thread) and that "extra" cable ...
I figured it MUST go from that electronics unit mounted on the firewall (what is that thing anyway? -- It's the PCM, G) to the G100 ground next to the airbox on top of the engine. So I set to disassembling things to replace that strap. Turns out that replacement cable is once again longer than the factory original ... too long to really deal with, in fact. The ring terminals are much larger than the original on the firewall end and much smaller on the G100 side, they just do not fit well and would need modification. Finally, the factory original is not very thick, I just cannot imagine that I really need a 2awg wire here, so I am ditching this cable, I do not need it.
(Edit: comparison pic of the factory and replacement cables side-by-side)
But on the downside, I somehow lost the nut that secures the G100 ground (and the starter cable) . Now I need to go find a replacement. Might just go pull one from a donor the next time I am there. (Edit: just restating that I found it wooo)
See less See more
8
Suspension Lift Follow-Up ... swap and flip the springs
Note: The handling problem I was trying to solve was eventually traced to the RF UCA bushing on the axle. (See post).
It's been nearly a year since I gave Bella her lift (see post). She has been twitchy in wind and traffic since then. Towing the travel trailer is an unpleasant experience, worse than the factory setup. :thumbdown:
Since then I replaced the rear out-of-spec Addco swaybar with a replacement Addco to eliminate contact points (success :thumbsup:), replaced the front (hollow) swaybar with a solid model from a 2004 donor WJ :thumbsup:, and then prematurely declared my handling problems as solved :facepalm:(another post).
Then I noticed she was sagging on the left side (see thread). On the day I measured it (2020/10/13), from the ground to the outer fender lip, the RF corner was 7/8" taller than LF, and the RR corner was 6/8" taller than LR. Turns out that the front OME springs have an A/B designation and the "A" spring is supposed to go on the driver side (thanks to @Mattyjm for pointing this out).
So I swapped them L-R on both ends. My rear springs do not have A/B tags but did them anyway. I also cannot tell if there is a top/bottom to these springs, but I flipped both the springs on the (new) right side.
I removed all of the Bilstein's during this process, and happy to report that they all appear to be in good shape. They were all quite difficult to compress during reinstallation using my Armstrong tools :barbell:. All of the spring isolators appear to be in good shape. Perches are solid, slightly rusty ... appears my paint job was not entirely effective.
Found that the front tires are rubbing just a bit. I have never noticed a noise, but the evidence is clear. Got a rub on the LF control arm and fender well, and a minor rub on the forward splash shield on both front corners:
I am surprised at the rub on the control arm, at full wheel lock there seems to be enough room under there but clearly there is not ... I think this points to axle not centered under the front, so I am going to shorten the track bar a couple turns and see if that fixes it. Really should have done that while I was swapping the springs, but did not happen.
On the rear, the springs are definitely different lengths. The difference is not huge, did not bother to measure, but now the longer one is on the left side. I thought they were the same length when I installed them ... Anyway, I did a side-by-side comparison and put a level across the top to show the difference:
Closing out this particular chapter with more pics of the front springs because there just are not enough pics in this post yet :D
LF at full droop (so blurry)
LF under load
RF at full droop
RF under load
Have driven it three times since the swap ... maybe better? Holding the jury this time until after my next towing excursion.
G
See less See more
Reactions: 2
12
Whip Flag / CB Antenna Mount
When roaming on the sand highway at Oceano Dunes OHV State Park (sometimes just called Pismo Beach, which is right next door), a whip flag is required for visibility. while the OHV park is still closed due to CORVID, I optimistically installed a more permanent pair of whip flag mounts in anticipation of the day when it reopens. I read about this idea somewhere on this forum I think, sorry I cannot remember who did it first, but here's what I did. Buckle up, here we go.
Parts List
  • Firestik SS-184 Dodge Ram Hood Antenna Mount (Amazon)(Firestik.com)
  • Tusk Quick Release 1/4" Pole Holder (Link)
This is what I installed. Firestik "stainless" steel. I guess it's stainless enough. Like so:
And I installed it above the tailight, here. You'll see.
1) Remove taillight
First, remove the phillips screws
Then reach in and grab the back of the housing. Hug it to your hip and give it a big yank straight back to pull it out of the mount.
2) Drill pilot holes and mount the bracket
Test fit the bracket, find where it fits best, and mark the holes.
Center punch the marks and drill out with 7/64" bit.
Mount the bracket. Not shown but very recommended: coat the top of the bracket with black RTV silicone to keep the water out. This bracket will ramp water down to the screws and rust out the mount if you do not. So seal it before you mount it. I just did this today.
3) Make it fit and put the light back in
Okay so the lights do not quite clear the panhead screws. So get a round file and clean out a bit of plastic from the top of the housing.
But I still needed more room to remount the light, so I round-filed a little extra room on the top mount.
And now it fits! Woooo
This is what it looks like with a whip flag installed. 'Merica. F**k yeah.
I did one on each side. You know, for balance. Should also mention that the nut/bolt I used that actually holds the flag was purchased elsewhere, from a vendor at Pismo Beach. But I think you can get flag poles that mount right into the Firestick threaded fitting.
Edit (2020/11/05): Replaced the pole nut with a blue quick-release style from Tusk. One on each side.
Happy Jeeping :)
See less See more
8
2002 WJ Grand Cherokee, Headliner Repair
My headliner was starting to peel, I finally got around to trying to fix it. I gave it the old college try, but cannot say it turned out great. Good enough.
1) Remove the sun visors and EVIC.
Sun visors are held on with two T25 screws and a phillips screw. They drop right down ... then disconnect the electrical. The EVIC is held up with one phillips screw and two spring clips. Remove the screw, grab the sides and pull straight down ... then disconnect the electrical. It is not that difficult, so no pictures this time.
2) Remove the grab handles and trim panel
This thing
Pull the rubber plugs out of the handle and remove the 7/32" screws.
The trim panel is held in with a spring clip. It is right in the middle of the panel, see here.
3) Prepare the sagging liner and mask the area
Since it is just a matter of time before the whole headline sags, I decided to prep the entire thing. Peel back what is not yet sagging and tape it up with some blue painter's tape. I did not want the adhesive spray to get on the dash (or anywhere) so I went nuts with protection. Cover everything with a plastic drop cloth.
4) Apply adhesive and reattach
Turns out you only need a light coating of this stuff. Get some on the fabric and the base of the liner.
Let it sit a bit, and then fold the fabric back. It will stick on contact, be careful, get it smooth. Smoother than I did ...
Not very happy with it, but it's better than it was. They cannot all be home runs.
See less See more
5
Undercoating
After seeing many posts from the midwest USA Jeep forum contingent where their undercarriage is rotting out from rust, I got to thinking. If I continue beach adventures with Bella, she is likely to get a bunch of saltwater on her belly which could cause some rot. So while the dunes continue to be closed, I figure this is a good time to take protective measures.
I decided to use 3M 3584 Professional Grade Rubberized Undercoating. This stuff is kind of expensive, more than $10 per can at the local parts store. I found a six-pack on Amazon for $50, what a deal.
1) Clean
Like any painting job, success depends on preparation: make sure the surface is clean or it will not stick. I used a tub of cleaning wipes from Home Depot to get the gunk off, and called that good enough (hope it is ... so far, so good). This pic is during removal of the gunk above the rear axle and upper control arm:
2) Coat liberally with spray
It will not protect if it is not a complete coat. The label recommends two coats ... Today I removed the heat shield above the exhaust to coat the undercarriage. Kind of difficult to hit this without spraying the pipes so I used a plastic sheet to keep the rubber off the exhaust, who needs that stink.
Cleaned and ready for spray. Mask the bolts so the heat shield can be reinstalled without goo plugging the threads. Area to the left has already been coated and then top-coated with some light blue paint. I figured a light color would help me identify any fluid leaks, should they occur.
After coating:
Also coated the skid plates, this is the rear fuel tank skid.
And this is the rocker panels in progress. Might as well include it here.
This project is till in progress, only about 25% left to coat.
See less See more
Reactions: 1
Looking good on the build. I did a quick look through, your post about the springs caught my attention. I am not sure what springs you are using but one may be slightly longer for a reason. sometimes they will be made slightly longer to help with sag due to the driver. I have also seen this done on JK springs that were designed to compensate for the fuel tank being mounted to the passenger side and not the center of the jeep
Mattyjm mentioned this to me as well in a different thread. The OME HD springs have A/B labels, at least in front they do. The recent swap has me hopeful that the issues have been addressed ... final decision in a couple weeks.
Reactions: 2
This is what I installed. Firestik "stainless" steel. I guess it's stainless enough. If you want one, look for a Dodge Ram hood mount bracket, FIRESTIK SS184. Like so:
1) Remove taillight
Then reach in and grab the back of the housing. Hug it to your hip and give it a big yank to pull it out of the mount.
Happy Jeeping :)
This is probably my favorite read so far....I love the comment on the top of the flag pic. 'merica!!!!!
Also balance is necessary in all things, especially your antenna/flagpoles....Just need a trump flag on the other side in my opinion...:smile2:
Suspension Lift Follow-Up, Part II
Last month I swapped and flipped the springs (see post). Since then I have driven it in many road conditions, and this last weekend I towed my Rpod out to the local Cachuma Lake campground.
Result: yes, handling is much improved. I would not say it is better than stock though, I would rate it about the same, but a bit worse that it was before the lift. I do think it now behaves a bit better in towing conditions.
So I have slightly taller springs, slightly taller tires, tows a bit better, and a suspension that behaves about the same as factory. I think that qualifies as mission accomplished.:woot:
Honestly do not know what the problem was. I had already tried re-torquing the front/rear CAs, so I guess it was the springs. Were they poorly installed? Well I installed them, so maybe that was it. Is it that important for the A spring to go on the left and B on the right? I guess it is ... would have been nice if the supplier told me about that instead of leaving me to guess. At any rate, I think it's as good as can be expected without further control arm investment.
See less See more
I am not satisfied with the amount of squat I see when I hook up the Rpod. There is a truck scale nearby that I can use whenever I want. Weights are:
  • Bella + me = 4700 lbs
  • Bella + me + Rpod on the hitch = 5100 lbs
  • Bella + me + Rpod = 8400 lbs
That means the Rpod is 3700 lbs and the tongue weight is 400 lbs ... I think that is about where it should be. But she sags in the rear at least 2 inches when I hook up. I do not like it, so I am thinking about air bags to supplement the springs.
Airlift makes a product for the WJ: 60754 (link).
I contacted a local dealer to see if these bags would fit with a 2-inch lift. They said they would find out and let me know ... that was over a week ago. Here I am trying to buy from local business and they hang me out to dry again, looks like I am on my own.
These essentially work as secondary springs. When you need them, add air and they provide more spring rate. When you don't need them, deflate to minimum and they do nothing. Sounds great, except for one thing: more springs without more shocks means more bouncing. Occasionally I hit a bump with the trailer and the whole rig rocks through a few cycles. I do not want to accentuate this condition.
So now I am wondering if there is another shock absorber solution out there for me.
Actually considering trying to math something up to see if I can figure out what I need from my shocks ... but multi-spring systems like this are far from trivial math.
I will probably go the lazy route: just get them and install them without doing any math, see if they work. Unless anybody else has a better idea.
See less See more
Gman, i would tend to think these would stiffen up your ride, just the amount you have been looking for. Sure you will add a small amount of bounce, but quality shocks should handle this just fine(I think you have the bilsteins?) I say forget the math and scrape your knuckles, and let me know if i wanna chase this kit too!:laugh2:
I've been eyeballing that same kit. I don't tow much but I will be towing a trailer across country next year when I move back to the east coast. Your research would greatly benefit me :wink2:
I called the local shop again. The guy said he does not recommend this style of airbag. Says that 80% of the "cheap balloon inside a coil spring" bags split along the seam.
So ... that's unfortunate. If it shows up under the Christmas tree, I will give it a whirl. Otherwise it sounds too risky for my dollars.
