Most of mine are broke too. I really wanted to rebuild the entire harness while I had my engine out, but time and money...
U can rent the tools at advance auto for price of tool and keep for 30 days , return and get all ur money back!It has been raining (badly needed) so I can't move the garage queen out to make room for WJ upgrades. Instead I have been reading the FSM, scouring this forum, watching videos, studying how to perform the front end suspension rebuild. In the meantime, parts have been arriving:
Moog tie rods & ends, Spicer ball joints. Control arms en route.
Never having done ball joints myself, I did not have a press, so I went to Harbor Freight to pick up a kit yesterday. Toying with the kit, I was having a hard time figuring out how this press was going to work with the WJ. My conclusion was that it was not going to work very well. Several forum posts that I read today backed that up, even saying that the HF press will bend because it is junk. What is worse is that installing the upper requires a receiver with an angled face to ensure it goes straight in, and the HF kit certainly does not have that. If you put in a ball joint slightly crooked, it will probably get damaged, and wind up being loose, sloppy, and dangerous. Then I finally found this post on page 5 or 6 of my search results:
http://www.jeepforum.com/forum/f310/ball-joint-replacement-1462599/#post14855003
So a big THANK YOU to texlurch for clearly listing the tools I need for this job:
OTC 7249 ball joint kit
OTC 7894 Jeep adapters
Ordered these tools from Amazon for just under $200 (ouch) and the HF kit ($113) is going back today. Better to have the right tools to do the job correctly than the wrong tools and have to do the job again. I read several discussions on this forum about redoing ball joint jobs several times before getting it right; I would rather not have to do it again!
There are also some good tips in this write-up from Stu's Offroad: http://www.stu-offroad.com/axle/balljoint/balljoint-1.htm
And thanks again to all the Jeep Forum users who have posted their war stories, writing down your experiences has helped arm me with the info I need to tackle these jobs!
Thanks for the heads-up, I appreciate it. We don't have Advance around here, but we do have a CarQuest which is now part of the Advance family. After looking online at the ball joint tools they have, I think I am going to stick with the OTC kits I have on the way. Specifically, I do not see an equivalent for OTC 7894. Those adapters might be included in the kits, but I cannot tell from the description.U can rent the tools at advance auto for price of tool and keep for 30 days , return and get all ur money back!
Glad my post was helpful to you! Yesterday the weather cleared so I got to work on the right bank electrical. But I got a late start and only managed to replace 3/4. There just isn't much room to work in there and the harness is very difficult to move around.Very nice! I have to do this to mine. All but one of the 8 are broke on mine. By reading your thread makes me realize it was easier than I thought.
O'Reilly really let me down yesterday. I had to remove the PCV breather hose to find enough room to get at the fuel injectors. The hose split due to age when I tried to reinstall, so needed replacement. Seems O'Reilly does not carry PCV hose in bulk and only has a few specialty pieces. What kind of auto parts store does not stock hoses?
Brother, it made a world of difference. The ride is so comfortable now, I am kicking myself for not doing this five years ago. Wandering is almost non-existent, bump steer is massively reduced, steering is much tighter. All I have left is the track bar bushings, but not sure if I am going to do that or just get a new track bar when I lift.How much better does she drive now with new CA's? I absolutely can't wait to get mine replaced! Runs SO loose right now!!
Nice detailed write-ups though! Nice job!
It's shocking to think that buying the proper OEM part can see you worse off than a part from an aftermarket manufacturer. Common sense would say that the OEM parts should be the best, but who can say how long some of these parts have been sitting in storage?In an earlier post, I wrote about replacing the rear lower control arms (https://www.jeepforum.com/forum/f310/2002-bella-blue-wj-build-thread-4239282/#post39694594). The job itself is easy enough. Getting a quality replacement part is not.
The Mopar control arms that I bought from Rock Auto were complete garbage, they only lasted a few months. She started lurching around when I would apply or remove throttle while cornering. It started small and just kept getting worse, to the point where it began feeling downright dangerous. Not knowing what else to do, I tried putting the old rear lower control arms back on. Result? Problem solved.
The bushings on the replacement control arms looked fine at first. Then I stuck a screwdriver through the inner metal sleeve and gave it a little pry, which opened a big gap between the sleeve and the bushing rubber (no pic yet). The sleeve had delaminated from the rubber.
I ordered a new pair of axles (with bushings) from Detroit Axle. I put this brand on the front and have had no problems yet, so I will give them a try on the rear.
As promised, here are pics of the Mopar control arms I bought from Rock Auto after running them a couple months. Cursory inspection shows no obvious problem.In an earlier post, I wrote about replacing the rear lower control arms (https://www.jeepforum.com/forum/f310/2002-bella-blue-wj-build-thread-4239282/#post39694594). The job itself is easy enough. Getting a quality replacement part is not.
