I have not had any additional DW since I put in the KOR track bar bushings and reverted to the stock (Detroit Axle) UCAs. I had a very minor shimmy that I did not like, I know it is the DW beast peeking at me, but it quickly disappeared. I could live with it like this if I had to. Rather not though.
You can sort of see the difference in pitch in this pic, granted the suspension is drooped at this point:
Frankly, I do not see the point of a drop pitman arm, seems like it would make the situation worse. Dropping the track bar mount seems more likely to fix the bump steer problem. See discussion: https://www.jeepforum.com/forum/f310/dropped-pitman-arm-1377801/
Thanks for the explanation. Is it weird that my steering wheel seemed mostly isolated from the whole incident? I mean, it wiggled a little, but most of the freakyness happened down below. I just applied brakes and pulled over to the side of the road until it stopped. I really had no trouble steering or controlling it ... but I for sure do not want it to happen again. And it has not.
Nope, no drop pitman arm installed. What you describe here is the same issue that causes bump steer, right? I have been kicking this concept around in my head for some time, but have not really cared enough to go further. I am not convinced that measuring the angle on the straight section of the arms is appropriate. By design, the track bar pitch angle is much steeper than the drag link so it can clear the differential. What seems more important is the invisible line between the mounting points: (A) the straight line between the pitman arm and the steering knuckle; (B) the straight line between the track bar mounts.
